> Rear suspension knock., Searching wasn't helpful.
post Jul 1, 2012 - 2:54 PM
richee3
Joined Jun 29, '08
From Denver
I recently installed TRD coilovers on the Celica to replace the aged stock suspension. The struts weren't totally blown but they weren't great and the springs had to have helper blocks in them, but they were quiet. After lowering, we found that the rear started knocking quite badly. Based on recent threads, I replaced the rear sway bushings with 16 mm with Energy Suspension bushings and the end links with Racing Beat Miata end links. While this cut the knocking down by half, there is still a persistent knock. It only happens at low speeds and seems to be from the right side more than the left, but it isn't strictly on one side or the other. All nuts and bolts have been checked and are confirmed to be tight.
When I searched, the only potential suspects I can find are trailing or control arms or the exhaust hitting the car. I don't believe it's the exhaust since it only happens at low speeds and I've followed the Celica and the exhaust seems stationary. So what are the odds that I need new rear bushings and it didn't become apparent until I was lowered? Anything else I should check? Any help or advice is greatly appreciated.
By the way, I'm intending to replace my rear bushings anyway, I just haven't done it yet. Procrastination is terrible.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
- richee3   Rear suspension knock.   Jul 1, 2012 - 2:54 PM
- - lagos   It could be caused by your upper strut mounts. Whe...   Jul 1, 2012 - 3:00 PM
- - richee3   Thanks Art! I'll check into it. I just tho...   Jul 1, 2012 - 5:25 PM
- - trdproven   retorque all nuts/bolts, check your sway bar bushi...   Jul 1, 2012 - 5:28 PM
- - richee3   So far, no luck. I haven't been able to replic...   Jul 10, 2012 - 12:31 PM
- - trdproven   are the bump stops gone or are you bottoming out a...   Jul 10, 2012 - 8:32 PM
|- - richee3   QUOTE (trdproven @ Jul 10, 2012 - 8...   Jul 10, 2012 - 9:06 PM
- - trdproven   did you remove the coilovers or just adjusted it? ...   Jul 10, 2012 - 10:33 PM
- - RabidTRD   Ok if you figure this out, I really need to know. ...   Jul 11, 2012 - 2:12 AM
- - Galcobar   Symptoms sound quite familiar. Worn-out bushing i...   Jul 11, 2012 - 4:43 AM
- - richee3   ^^ Thanks! I'll have to test that next wee...   Jul 11, 2012 - 10:51 AM
- - trdproven   seen that diagram to replace those bushings and ar...   Jul 11, 2012 - 5:57 PM
- - azian_advanced   that's the diagram i made a while back. i not...   Jul 11, 2012 - 8:22 PM
|- - richee3   QUOTE (azian_advanced @ Jul 11, 2012 - 8...   Jul 11, 2012 - 8:46 PM
- - Galcobar   The problem's actually fairly common. It spark...   Jul 11, 2012 - 11:32 PM
- - richee3   Thanks guys. I've got some stuff to test for s...   Jul 12, 2012 - 3:04 PM
- - jordisonjr   ^ Yea those bolts also look like a royal pain to g...   Jul 12, 2012 - 4:04 PM
- - richee3   bloodMoney has a set of rear suspension bushings t...   Jul 13, 2012 - 2:55 PM
- - jordisonjr   If you're dropping the gas tank, and are looki...   Jul 13, 2012 - 3:21 PM
- - azian_advanced   i got somebody else to remove the one bushing on t...   Jul 13, 2012 - 5:04 PM
- - richee3   QUOTE (jordisonjr @ Jul 13, 2012 - 3...   Jul 13, 2012 - 5:49 PM
- - trdproven   the one I am trying to get over, which is for many...   Jul 14, 2012 - 7:03 AM
- - Galcobar   If the pop is due to the arm binding, there are tw...   Jul 14, 2012 - 1:32 PM
- - trdproven   makes sense, would the bind be more likely due to ...   Jul 14, 2012 - 5:54 PM
- - Galcobar   The suspension arm would bind because the bushing ...   Jul 15, 2012 - 4:35 PM
- - trdproven   i might have to get to this point one day, cus i k...   Jul 15, 2012 - 11:08 PM
- - richee3   Little update, I've got the bushings now, so I...   Jul 26, 2012 - 3:25 PM
- - Syaoran   Having a similar issue: Low speed bumps causes a ...   Aug 24, 2012 - 5:18 PM
- - jordisonjr   Is it only when you hit bumps unevenly? And no noi...   Aug 25, 2012 - 12:21 AM
|- - Syaoran   QUOTE (jordisonjr @ Aug 25, 2012 - 1...   Aug 25, 2012 - 10:22 AM
- - richee3   Syaoran, that sounds like sway bar bushings to me....   Aug 25, 2012 - 2:08 PM
|- - Syaoran   QUOTE (richee3 @ Aug 25, 2012 - 3:08...   Aug 25, 2012 - 2:47 PM
- - 955SFE   Did OP ever find the solution? I am having almost...   Apr 20, 2013 - 6:32 PM
|- - richee3   QUOTE (955SFE @ Apr 20, 2013 - 6:32 ...   Apr 20, 2013 - 7:34 PM
- - travisxcore   Check your caliper pins. When they dry out they te...   Apr 20, 2013 - 6:50 PM
- - 955SFE   QUOTE (travisxcore @ Apr 20, 2013 - 7...   Apr 21, 2013 - 6:25 PM
Lo-Fi Version Time is now: August 21st, 2026 - 10:36 PM
