> Got my 7A-FE back from the machine shop...., need some advice
post Jul 9, 2012 - 11:55 PM
PaukST
Joined Mar 15, '12
From Wrightstown, NJ
So I just finally got my engine back from the machine shop. woot.gif ...Of course, being paranoid like I am, I installed the new bearings and threw some plastigauge on each main journal to check clearance. According to the Haynes manual it's supposed to be between 0.0006" and 0.0013". Well, after torquing down the caps ( in proper order, multiple passes to 44 ft./lbs ), it looks like my oil clearance is between 0.0015"-0.002" across the board.
So basically, I just need some advice on how severe of an issue this actually is, and if I should be taking it back to the machine shop to have it re-done "right". confused.gif
Edit: Just wanted to add that I did the measurement 100% dry... no oil under or on the bearings or journals (of course super careful not to turn the crank in this state). I'd much rather hear that I did something wrong (if indeed I have) than incur additional machine shop delays or end up on a wild goose chase!
This post has been edited by PaukST: Jul 10, 2012 - 12:54 AM
1989 Celica ST Automatic "King Cobra" -- 2005-2006
1994 Celica ST 5-speed "King Cobra II" -- 2011-????
Replies (1 - 3)
post Jul 10, 2012 - 1:16 AM
Box
Joined Feb 23, '12
From Warrior, AL
Specs are there for a reason, but being such a small amount off I wouldn't think it'd cause a problem. I'd wait until someone experienced with engine builds comments though.
2001 Miata LS 5-speed
post Jul 16, 2012 - 9:33 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
you are fine. 1.5 to 2 thousands is ok.
this is right out of the Toyota Manual, i dont trust Haynes or Chiltons
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Jul 19, 2012 - 11:43 PM
PaukST
Joined Mar 15, '12
Awesome, thanks Smaay. I decided to rebuild anyway with the clearance I had, but I had to order a new set of bearings... When I torqued the caps down the first time I apparently allowed one solitary grit of something to be between one journal and its bearing, which put a burr in the bearing material. frown.gif
Anyway, that's really a load off my mind!
Lo-Fi Version Time is now: August 29th, 2026 - 6:29 PM
