> Best way to hunt down an oil leak?
post Jul 16, 2012 - 7:40 PM
caribou17
Joined May 29, '12
From British Columbia
Well i did an oil change on the car today its the first I've done on the Celica because i just got it not to long ago, Anyways, Theres a lot of oil underneath, I had the car parked in the same spot for 9 days while i was away and i just got back a few days ago and there was NO oil on the ground at all,,,Should i try and clean it up underneath and then try and see where its coming from? ( i also have to use someone else's lift for the car so i kind of want to know what i should be looking for etc)
- caribou17   Best way to hunt down an oil leak?   Jul 16, 2012 - 7:40 PM
- - Special_Edy   QUOTE (caribou17 @ Jul 16, 2012 - 8...   Jul 16, 2012 - 10:49 PM
|- - caribou17   QUOTE (Special_Edy @ Jul 16, 2012 - 11...   Jul 16, 2012 - 11:55 PM
- - Smaay   clean the engine really good. then look to see whe...   Jul 16, 2012 - 10:51 PM
- - trdproven   its really hard to say if the leak happened before...   Jul 16, 2012 - 11:01 PM
- - trdproven   i'd clean it up and check. is it leaking from...   Jul 17, 2012 - 1:47 AM
|- - caribou17   QUOTE (trdproven @ Jul 17, 2012 - 1...   Jul 17, 2012 - 1:47 PM
- - richee3   I can't remember what it's called right no...   Jul 17, 2012 - 2:48 PM
- - Tigawoods   I bet its the same leak I have. Where do you se...   Jul 17, 2012 - 2:51 PM
|- - caribou17   QUOTE (Tigawoods @ Jul 17, 2012 - 3...   Jul 17, 2012 - 3:19 PM
- - Tigawoods   I will let you know in a couple weeks. My primary...   Jul 17, 2012 - 4:34 PM
- - trdproven   can be there...but you can use those UV dye crap b...   Jul 17, 2012 - 5:14 PM
- - caribou17   Okay well i just checked my spark plugs, and in th...   Jul 17, 2012 - 5:27 PM
- - Box   Sounds like bad oil rings or valve seals on cylind...   Jul 17, 2012 - 5:56 PM
- - Bitter   Start with a valve cover gasket with tube seals an...   Jul 17, 2012 - 6:57 PM
- - Box   Ah yes, definitely try valve cover and spark plug ...   Jul 17, 2012 - 9:29 PM
- - caribou17   Alright well i did what you guys said and got new ...   Jul 17, 2012 - 10:07 PM
- - caribou17   Well the spark plug seals that i changed definitel...   Jul 21, 2012 - 1:11 AM
- - Bitter   Little dirty, nothing horrible. Run some auto tran...   Jul 22, 2012 - 10:32 AM
|- - caribou17   QUOTE (Bitter @ Jul 22, 2012 - 10:32...   Jul 22, 2012 - 3:16 PM
- - Bitter   ATF has good detergency and will clean things gent...   Jul 22, 2012 - 4:23 PM
Lo-Fi Version Time is now: August 31st, 2026 - 12:43 AM
