Jul 17, 2012 - 12:28 PM
Enthusiast ![]() Joined Jun 23, '10 From Pawtucket, RI Currently Offline Reputation: 2 (100%) |
I'm having trouble with my celica with start up where its not idling where it should be instead it idles around 200 and would shut off. but this only happens on ocassion. I noticed that 2 of my spark plugs are wet with oil so I cleaned them up and the problem still occurs. I called Toyota and was told to replace the tube seals but this didn't fix the issue. Could it be the valve guide seals at this point? Also my car is not throwing smoke BUT it does smell like burning oil on cold starts till she warms up. Any suggestions would help.
-------------------- I only want to be faster than the guy next to me.
Jul 17, 2012 - 5:15 PM
not sure but valve guide seals usually come with smoke because it leaks down. how is your ignition timing? How did this all start? Try providing a history up to problem.
Jul 18, 2012 - 4:16 PM
The timing is good, as far as how this came to be it started happening after I replaced my spark plug wires because all 4 were ripped apart at the point that they connect to the spark plug. A week after I replaced them the problem starting to occur
Jul 18, 2012 - 5:23 PM
do you have a leak at your dizzy?
Jul 23, 2012 - 1:03 PM
do you have a leak at your dizzy? sorry but what exactly is a dizzy? -------------------- I only want to be faster than the guy next to me.
Jul 23, 2012 - 1:22 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 29, '09 From Gainesville, FL Currently Offline Reputation: 17 (100%) |
Distributor
Jul 24, 2012 - 7:11 AM
Enthusiast ![]() ![]() ![]() Joined May 23, '12 From northridge,CA Currently Offline Reputation: 3 (100%) |
My car has the same issue it's a 99 and I replace valve coer and tube deals and it still leaks and occasionally it will idle at cold start so idk what to do anymore but as far as smoke I never seen a sight of it yet
Jul 24, 2012 - 11:30 AM
Also all I do to get rid of the issue is let it warm up a little and give it a quick rev to 5K and it work good as new
Jul 24, 2012 - 7:03 PM
I think that might help mine too but I can't rev it up to 5 If its not ready or warmed up cuz eventually it will catch on
Jul 25, 2012 - 1:48 PM
Enthusiast ![]() Joined Apr 22, '12 From florida Currently Offline Reputation: 1 (100%) |
Mine had a similar problem, only difference is it only does it when its really hot outside. In the morning or at night it starts no problem in the middle of the day it seems fuel starved
Jul 26, 2012 - 11:52 AM
So it seems like its not too uncommon, somebody has to have a solution for this annoying issue
Jul 26, 2012 - 7:32 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Mar 7, '10 From Ft. Lauderdale Currently Offline Reputation: 9 (100%) |
mine does that too. (i dont know about the oil part, but the dieing on start-up is my car) only when its really hot outside though, and like a post before, a quick rev and its back to normal. (i dont go to 5k though, just to 2 and then hold it at 1.5 for a few seconds) im taking it to my mechanic on monday and let you know if he fixes it and if so, what it is.
Jul 27, 2012 - 7:25 AM
mine does that too. (i dont know about the oil part, but the dieing on start-up is my car) only when its really hot outside though, and like a post before, a quick rev and its back to normal. (i dont go to 5k though, just to 2 and then hold it at 1.5 for a few seconds) im taking it to my mechanic on monday and let you know if he fixes it and if so, what it is. lets hope he atleast gives you an idea of what it may be. its really embarrasing going to school for automotive technology and this problem happens in front of everyone lol. -------------------- I only want to be faster than the guy next to me.
Jul 28, 2012 - 10:46 PM
i just have to bump this, too many people with the same problems
Aug 9, 2012 - 9:29 PM
Enthusiast ![]() Joined Jan 3, '12 From Philadelphia, PA Currently Offline Reputation: 1 (100%) |
try cleaning the throttle body & check air idle control operation.
Aug 10, 2012 - 7:03 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 11, '08 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) |
yeah, maybe clean out the idle control valve, pull the hose off and see if its sucking much air thru it
-------------------- Mike W
Aug 13, 2012 - 8:56 AM
cleaned out my IACV yesterday and this morning i had trouble starting it. it would turn over and shut off right away. im slowing starting to give up on this.
Aug 14, 2012 - 9:49 AM
Aug 14, 2012 - 2:10 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Apr 11, '09 Currently Offline Reputation: 11 (100%) |
ive heard that if your check engine light doesnt illuminate you need a new ecu.
Aug 15, 2012 - 10:24 AM
cleaned out my IACV yesterday and this morning i had trouble starting it. it would turn over and shut off right away. im slowing starting to give up on this. Another had to do an ECU swap to fix this..have you tried such? Know anyone to swap with? I know nobody else with a ecu I could try. And after cleaning the iacv the problem only got worse cause now it has trouble every morning and it idles rough -------------------- I only want to be faster than the guy next to me.
| Lo-Fi Version | Time is now: August 31st, 2026 - 9:13 AM |
