Jul 17, 2012 - 12:37 PM
Enthusiast ![]() Joined Feb 28, '03 From So-Cal Currently Offline Reputation: 1 (100%) |
i need help trying to diagnose a problem i noticed with a celica a recently bought. the front passenger wheel looks off center in the wheel well. when driving, there is a noise coming from that side too. being off center, when i make right turns the wheel rubs on the inside plastic cover. what can be the problem/problems?? thanks in advance guys.
Jul 17, 2012 - 2:31 PM
Enthusiast ![]() ![]() Joined Jul 24, '08 From Canoga Park CA. Currently Offline Reputation: 0 (0%) |
i need help trying to diagnose a problem i noticed with a celica a recently bought. the front passenger wheel looks off center in the wheel well. when driving, there is a noise coming from that side too. being off center, when i make right turns the wheel rubs on the inside plastic cover. what can be the problem/problems?? thanks in advance guys. This is a tricky problem. I bought a z car years ago and it would pull and it took me 6 months to find it was damaged in an auto accident. It could not be fixed easily(the bottom of the wheel hit a curb and shifted the brace over) so I transfered all the interior to a functional engine and shell and had a nice little car. On the other hand My celica when I bought it for 1500 was pulling slightly to the right. I measured everything and it seemed ok. As a last resort I replaced the struts(front) and noticed the spring was twisted out of the seat making the strut taller on the right side. That being said the wheel was angled and after I fixed it my car drives perfectly straight. You really have to inspect both sides. Good luck |
Jul 17, 2012 - 2:34 PM
thanks xrav, im going to have a look at it today after work. judt wanted to know where to start first. hopefully it isnt too much work to do myself.
Jul 17, 2012 - 2:36 PM
Off center which way? Up/down; front/back or in/out.
Your best bet may be to take it to an alignment shop and let them diagnose it. Just tell them you want a 4 wheel alignment(2 wheel is useless on ours) and that you suspect something in the front end is bent. Perhaps you can work out a deal where they could find the problem for you and then realign it once its fixed. Good luck with it and let us know the details |
Jul 17, 2012 - 2:44 PM
the wheel looks like its sitting back more. the back of the tire rubs when making right turns.
Jul 17, 2012 - 3:41 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined May 3, '11 From Ohio Currently Offline Reputation: 8 (100%) |
bent lower control arm?
Jul 17, 2012 - 5:22 PM
damaged suspension or something else damaged pushing more to the rear.
Jul 17, 2012 - 5:41 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 17, '08 From JB MDL, NJ Currently Offline Reputation: 30 (100%) |
Caster? On a Celica? Didnt know that we had that option.....
Jul 17, 2012 - 9:17 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Jun 2, '08 From Fort Worth, Texas Currently Offline Reputation: 9 (100%) |
check the lower control arm bushings
Jul 17, 2012 - 10:00 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '05 From Calgary Currently Offline Reputation: 20 (100%) |
Jul 19, 2012 - 2:15 AM
ill get pics of it up tomorrow.
This post has been edited by celicaracer8o5: Jul 19, 2012 - 2:16 AM |
Jul 21, 2012 - 12:46 AM
Front Passenger's side
![]() Front Driver's side
Jul 21, 2012 - 1:03 AM
I maintain....
Jul 21, 2012 - 1:19 AM
lower control arm?
Jul 21, 2012 - 8:44 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 29, '09 From Gainesville, FL Currently Offline Reputation: 17 (100%) |
Looks just like my ST's wheel after the wreck. Bent lower control arm as others said, or the bushing around the bolts that hold such arm are blown I estimate.
Jul 21, 2012 - 11:04 AM
Does that tire show any signs of uneven wear? I'm assuming so, but it's worth checking. Put the car on jack stands and see if you can find anything loose or immediately see anything that is bent.
Any strange knocking noises? Do all body panels line up and have uniform panel gap? If you're lucky, it's something as simple as a previous owner hitting a curb and bending the control arm. If you're unlucky.... That might be frame damage and the previous owner neglected to mention any accidents. For right now, I'm leaning towards bent control arm. -------------------- "Employ your time in improving yourself by other men's writings, so that you shall gain easily what others labored hard for." -Socrates. Even Socrates told us to use the search button!
Jul 23, 2012 - 11:12 AM
......Put the car on jack stands and see if you can find anything loose or immediately see anything that is bent. Well at that point you might as well remove the wheels and get under there and check everything out. I'm surprised that you havent done so yet.......or maybe you did. |
Jul 23, 2012 - 12:57 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 10, '10 From MA Currently Offline Reputation: 37 (100%) |
Yeah that passenger wheel is a lot farther back than it should be
Jul 23, 2012 - 1:07 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 20, '09 From Winnipeg Currently Offline Reputation: 5 (100%) |
I'd definately have to say Bent Lower control arm.
OR, if there is a clunking every time you engage the car in gear, or begin breaking (Meaning the wheel is moving forward and back, pivoting about the lower control arm) then check out the bushings. Thats what happened with my car before I replaced the bushings. -------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
Jul 23, 2012 - 1:22 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 7, '03 From Northern Virginia Currently Offline Reputation: 23 (100%) |
also check where the strut tower connects to the car / compare to the other side.
| Lo-Fi Version | Time is now: August 30th, 2026 - 2:32 AM |
