Jul 19, 2012 - 9:37 PM
Enthusiast Joined Sep 11, '09 From MA Currently Offline Reputation: 0 (0%) |
Been having month s of issues with my 96 celica GT 2.2
Last year I turned 170k miles. The transmission started to get stuck in gear; and sometimes it would not come out of gear. A friend of mine had a low mileage 60k transmission that he gave me, so i pulled the trans and noticed that the rubber springs on the clutch disk dry rotted out. I decided to install the other trans and also put in a new clutch, pressure plate and throw out bearing. It seemed to shift fine for a few months until it started to give me trouble shifting gears again. It would not come out of gear and sometimes requires me to stop and shutdown the engine, then shift into gear and start it back up. It would then shift okay for a few miles and eventually would give me trouble going into reverse. I pulled the transmission and noticed that the shift fork was not pushing evenly on both sides of the throwout bearing. The fork end at the slave cylinder would sometimes be misaligned with the shaft sticking out of the slave cylinder. I would have to pull up or push down on the fork end to realign it. It would work for a while and then misalign and cause trouble. I pulled the transmission and replaced the throwout bearing because it appeared like the center tube in the bearing was crooked. I bought a new one, but it looked crooked just like the old one. I put a new one in anyway. After getting it all together it seemed to work fine for a few miles but then started to get stuck and whine while partially pressing down the clutch pedal. The shifter does not seem to go into gear positively....it seems soft...not firm. Not sure what it could be. Not sure why it is doing it again. This post has been edited by apekim: Jul 19, 2012 - 9:39 PM |
Jul 19, 2012 - 9:52 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 18, '09 From Orlando Currently Offline Reputation: 8 (100%) |
Replace the fork with a new unit. Did you inspect the shifter cables?
This post has been edited by SwissFerdi: Jul 19, 2012 - 9:52 PM -------------------- '97 ST \ Eibach \ KYB \ Kenwood \ Alpine \ Cusco \ OEM+ [sold 10/18]
'90 MX-5 Mariner Blue '93 MX-5 LE '07 Kawasaki Eliminator 125 silver '15 Optima Grey '04 206 GTi silve |
Jul 19, 2012 - 10:03 PM
The fork seemed fine with no unusual wear. I am not sure what to look for when checking the shifter cables. It will shift into all gears very easily when not running, so I assume the cables are fine.Do the shift cables have an adjustment?
Jul 19, 2012 - 11:10 PM
They do not have an adjustment that I can think of.
Jul 19, 2012 - 11:22 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 23, '11 From kenton ohio Currently Offline Reputation: 14 (100%) |
Weak slave cyl or clutch master cyl maybe
Or air in the line -------------------- 95 gt coupe, v6 swap weekend toy
Jul 20, 2012 - 3:15 PM
I put in a new slave prior to putting the clutch in. I put another slave in prior to pulling the transmission the second time. I also rebuilt the clutch master cylinder. Any other ideas?
Jul 20, 2012 - 5:10 PM
Weak slave cyl or clutch master cyl maybe Or air in the line this is your problem -------------------- 2001 Celica GT-S Turbo
Jul 20, 2012 - 6:53 PM
Mine was doing this on a much smaller scale cuz had air in the line
Get a buddy to help you an pump the crap out of your clutch pedal for as long as you can Do it as hard an as fast as you can ( that's what she said giggity giggity) an once you leg starts to get tired. Have you buddy crack the bleeder open an shut quick then switch spots an do it again I normally so this 3 to4 times then give my leg a rest then go see how it feels -------------------- 95 gt coupe, v6 swap weekend toy
Jul 23, 2012 - 7:28 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 29, '09 From Gainesville, FL Currently Offline Reputation: 17 (100%) |
If you do not have help to bleed it, just open the line put a tube on the breather and feed it down to a jar with about 2 inches of fluid in it. Pump it about 5 times, fill the res back up, rinse repeat about 3-4 times.
| Lo-Fi Version | Time is now: August 27th, 2026 - 11:52 AM |
