> WTB: Broken Driverside Projector, ... just need the housing, tabs IN TACT
post Jul 24, 2012 - 1:06 PM
KAOS
Joined Apr 18, '06
From Calgary, Canada
As the subject says, I need your busted un-usable driverside projector (broken glass, etc). I need to replace the housing of the one I have with one that still has all the mounting tab's in tact. Turns out the halogen housings are different than the projector ones, so its not a matter of simply swapping them out like I originally thought...
Can anyone help?
Replies (1 - 11)
post Jul 24, 2012 - 8:51 PM
Araykhel
Joined Sep 21, '10
From Woodstock, MD
QUOTE (KAOS @ Jul 24, 2012 - 2:06 PM) *
Can anyone help?
You didn't wreck or anything did you?
post Jul 24, 2012 - 8:54 PM
KAOS
Joined Apr 18, '06
QUOTE (Araykhel @ Jul 24, 2012 - 7:51 PM) *
Nope. Just bought a set of used projectors, and the tabs were broke during shipment. biggrin.gif biggrin.gif
... can't get in a wreck if you don't drive your car - and mine has been parked for almost 5 years. kindasad.gif
post Jul 26, 2012 - 12:46 PM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
Well, cax_11 has a driverside projector witg broken glass for sale here
http://www.6gc.net/forums/index.php?showtopic=83902
I think he said one tab is damaged though
post Jul 26, 2012 - 5:09 PM
KAOS
Joined Apr 18, '06
QUOTE (Special_Edy @ Jul 26, 2012 - 11:46 AM) *
post Jul 26, 2012 - 5:48 PM
Araykhel
Joined Sep 21, '10
From Woodstock, MD
QUOTE (KAOS @ Jul 26, 2012 - 5:09 PM) *
Why not fiberglass new tabs? Took me all of an hour to replace the tabs l have on my crashed headlamps today.
This post has been edited by Araykhel: Jul 26, 2012 - 5:49 PM
post Jul 26, 2012 - 9:18 PM
Special_Edy
Joined Oct 29, '11
could a regular USDM headlight be combined or modified to work?
post Jul 26, 2012 - 9:21 PM
KAOS
Joined Apr 18, '06
QUOTE (Special_Edy @ Jul 26, 2012 - 8:18 PM) *
I thought the same thing, because I have a ton of USDM housings after my last projector retrofit project; but after close comparison I've noticed the USDM is shorter than the JDM one... probably to compensate for the projector inside the housing.
This post has been edited by KAOS: Jul 26, 2012 - 9:21 PM
post Jul 26, 2012 - 9:22 PM
Box
Joined Feb 23, '12
From Warrior, AL
If the tabs were broken during shipment, should be able to epoxy them back on.
2001 Miata LS 5-speed
post Jul 26, 2012 - 9:32 PM
zfjohnson07
Joined Apr 11, '09
i had a guy tell me that you can plastic weld them,
post Jul 26, 2012 - 10:52 PM
KAOS
Joined Apr 18, '06
QUOTE (zfjohnson07 @ Jul 26, 2012 - 8:32 PM) *
post Jul 27, 2012 - 9:16 AM
Special_Edy
Joined Oct 29, '11
Use some thin sheet metal cut out to the apx. shape and resin that into the repair. The repair needs to hold up better than the original tabs
Lo-Fi Version Time is now: September 13th, 2026 - 7:20 AM
