> ECT Sensor Connector, Camry one is compatible?
post Jul 24, 2012 - 6:28 PM
ILoveMySilly97
Joined Mar 8, '12
From Hanford/Fresno, Ca
Hey, as some of you members know I had overheating problems. The good news was that it was never over heating. It was a broken/loose ECT sensor connector that wasn't working properly so it showed the gauge that it was overheating when it never really was. So I'm looking around for ECT Sensor connectors and I'm going to go to local junkyards. Most likely they won't have a 6gc there so I'm HOPING that the L4 engine camry's have the same connectors. Anyone know?
post Aug 1, 2012 - 1:21 AM
Nihil
Joined Jul 17, '12
From Slovenia
If you got an 1.8L 7A-FE engine in your Celica - mechanic told me that overheating problem is pretty common with it... He suggested me that I replace the thermostat at the next service. Perhaps this might solve your future overheating problems.
Don't know about the ECT connector though.
post Aug 1, 2012 - 10:38 PM
ILoveMySilly97
Joined Mar 8, '12
QUOTE (Nihil @ Aug 1, 2012 - 1:21 AM) *
I have the GT model with the 5sfe engine. My engine is not overheating at all. It's a "mis-communication" signal that's sent from the ECT to my dash that's "lying" what it reads.
post Aug 10, 2012 - 12:05 AM
ILoveMySilly97
Joined Mar 8, '12
Anyone know? I'm going to pick and pull this connector from a 97 Camry LE from a local junk yard sometime soon. I know the connector looks the same but we will have to see.
post Aug 10, 2012 - 1:26 AM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
As far as I know even with the later 5SFE the temperature gauge sender and the engine coolant temperature sensor are different pieces.
You should also be able to test your temperature sensors with a multi-metre, a thermometer and a pot of water.
post Aug 10, 2012 - 1:48 AM
Box
Joined Feb 23, '12
From Warrior, AL
GEO PRIZM (1993 - 1997)
LEXUS ES300 (1993 - 2001)
LEXUS GX470 (2003 - 2005)
LEXUS LS400 (1993 - 2000)
LEXUS LX470 (1998 - 2004)
LEXUS SC400 (1993 - 2000)
TOYOTA 4RUNNER (1995 - 2005)
TOYOTA AVALON (1995 - 2003)
TOYOTA CAMRY (1994 - 2001)
TOYOTA CELICA (1994 - 1999)
TOYOTA COROLLA (1993 - 1997)
TOYOTA LAND CRUISER (1998 - 2006)
TOYOTA PASEO (1995 - 1999)
TOYOTA RAV4 (1996 - 1999)
TOYOTA SEQUOIA (2001 - 2005)
TOYOTA SIENNA (1998 - 2002)
TOYOTA SOLARA (1999 - 2003)
TOYOTA SUPRA (1993 - 1998)
TOYOTA T100 (1994 - 1998)
TOYOTA TACOMA (1995 - 2006)
TOYOTA TERCEL (1994 - 1998)
TOYOTA TUNDRA (2000 - 2005)
All these vehicles share the same temperature sender/sensor.
This post has been edited by Box: Aug 10, 2012 - 1:49 AM
2001 Miata LS 5-speed
post Aug 12, 2012 - 2:29 PM
ILoveMySilly97
Joined Mar 8, '12
QUOTE (Box @ Aug 10, 2012 - 1:48 AM) *
Is it possible to ask where you got this information from? I need to replace it ASAP because my car isn't getting proper electrical ground because of it. I'm thinking it's now causing my car to struggle for every start also because of the improper ground.
post Aug 12, 2012 - 4:14 PM
Box
Joined Feb 23, '12
From Warrior, AL
If I told you, I'd have to kill you. cwm13.gif Just kidding, here ya go: Rock Auto
post Aug 13, 2012 - 11:37 AM
ILoveMySilly97
Joined Mar 8, '12
QUOTE (Box @ Aug 12, 2012 - 5:14 PM) *
Thanks.
post Aug 27, 2012 - 10:08 PM
ILoveMySilly97
Joined Mar 8, '12
Aight so I got the pigtails and I need to sodder or just put a wire nut. I was thinking of using a wire nut since it's easier but what worries me is how hot it gets under the hood. Does anyone know the rating temperature I should be looking for? I heard of people heat shrinking and that's what's recommended but I want to use a wire nut instead since it's easier but if it can't be helped then I guess I'll go with soddering and heat shrinking.
post Aug 27, 2012 - 10:52 PM
Box
Joined Feb 23, '12
From Warrior, AL
post Aug 28, 2012 - 1:26 PM
ILoveMySilly97
Joined Mar 8, '12
QUOTE (Box @ Aug 27, 2012 - 11:52 PM) *
Hahaha. Yea I guess I'll just go with that then.
Lo-Fi Version Time is now: June 10th, 2026 - 2:33 AM
