> ...wont go in gear...
post Jul 30, 2012 - 8:25 PM
cajon
Joined Jul 22, '07
From Hendersonville,Tn.
Did an engine swap. Engine runs great, but trans wont go in gear. Yes, i double checked my linkage, its fine, moving as it should. Now what, ...troubleshooting ideas, please. Thanks, the ragin cajun. p.s. Its an auto trans.
This post has been edited by cajon: Jul 30, 2012 - 8:27 PM
Replies (1 - 12)
post Jul 30, 2012 - 8:46 PM
mkernz22
Joined May 10, '10
From MA
did you put transmission fluid in?
post Jul 31, 2012 - 12:09 PM
celica74
Joined Feb 8, '10
From North Carolina
shift lock?
post Jul 31, 2012 - 1:30 PM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
QUOTE (cajon @ Jul 30, 2012 - 9:25 PM) *
I second the fluid level comment.
Did you put the torque converter bolts back in? Ive seen sillier mistakes before.
A test for you- check the fluid level on the dipstick with the engine OFF. Now check it with the engine running and the trans in park. Now check it with it in drive while running( be safe dont run yourself over!). The fluid should drop on the second two checks, if the fluid level is the same your trans fluid pump is shot. The pump and the torque converter would be the only reason I can think of why it wouldnt engage in any gear.
post Jul 31, 2012 - 5:01 PM
cajon
Joined Jul 22, '07
QUOTE (Special_Edy @ Jul 31, 2012 - 2:30 PM) *
Duh, ...In all my getting I forgot the trans fluid. Ok, got the trans fluid in, now i have a new problem. Its turning over fine, but wont start. Btw, does anyone have a spare starter relay, i'm starting my car(or, I was) with a screwdriver,lol.
post Jul 31, 2012 - 7:59 PM
Special_Edy
Joined Oct 29, '11
Try swapping the relay next to it to see if that restores starter function, that way your sure the relay is the issue.
This post has been edited by Special_Edy: Jul 31, 2012 - 7:59 PM
post Aug 1, 2012 - 10:58 AM
cajon
Joined Jul 22, '07
QUOTE (Special_Edy @ Jul 31, 2012 - 7:59 PM) *
I know the starter relay is bad, that's why i was using a screwdriver to complete the circuit. Prob is, ...now that i have the trans fluid in, its not starting. I know it getting fuel because it started before i put the trans fluid in, so why wont it start now? The trans fluid doesn't effect the fire, so whats the freaking deal?!
post Aug 1, 2012 - 12:00 PM
celica74
Joined Feb 8, '10
From North Carolina
a quick and easy way to see if its getting fuel is to take some carb cleaner and spray some past the throttle body, turn it over. If it runs you have a fuel problem, if it doesnt it has an ignition problem.
post Aug 1, 2012 - 3:27 PM
cajon
Joined Jul 22, '07
QUOTE (celica74 @ Aug 1, 2012 - 1:00 PM) *
Its getting fuel. I know this because, after I turn it over and stop, fuel comes back out of the throttle body(I've got the air intake off of it). Its just weird that this happened right after i put trans fluid in. I know it shouldn't have anything to do with it, and yet...
post Aug 1, 2012 - 5:21 PM
Are the grounds proper? Those can be finicky.
This post has been edited by SwissFerdi: Aug 1, 2012 - 5:21 PM
'90 MX-5 Mariner Blue
'15 Optima Grey
'04 206 GTi silve
post Aug 1, 2012 - 5:34 PM
mkernz22
Joined May 10, '10
From MA
Fuel....coming out of the throttle body? I think that's your issue right there.
post Aug 2, 2012 - 11:34 AM
celica74
Joined Feb 8, '10
From North Carolina
QUOTE (mkernz22 @ Aug 1, 2012 - 5:34 PM) *
i guess thats the proper definition of flooding an engine.
post Aug 2, 2012 - 12:06 PM
Special_Edy
Joined Oct 29, '11
We are gonna need more details to help you out
Lo-Fi Version Time is now: August 27th, 2026 - 4:23 PM
