> Tourqe stear or somthing
post Jan 8, 2004 - 11:32 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
Ok every time i drive, i notice that when i hit the gas it always seems to pull to the left, im sure cause thats cause the one wheel drive...to left side. I wasnt sure if any one noticed this, or what. I know my alignment is fine, it drives stright an all, just pulls alot..maybe im not used to it, my last car was bmw, but my bros civic dosnt do it, i dont know any way to change this, thanks for reading..
post Jan 8, 2004 - 11:35 PM
Justin
Joined Dec 13, '03
From Alabama
mine was having some mad tourqe steer today in the rain and mine pulls to the left when I floor it too but ony in like 1st and 2nd
post Jan 8, 2004 - 11:58 PM
macavely
Joined Nov 4, '02
have you check the tire tread???
post Jan 9, 2004 - 12:10 AM
FallenHero
Joined Dec 26, '02
From Alabama
Our cars are one wheel wonders?
BigEdge169
Joined Nov 18, '02
From Texas
yeah you might want to check the tires because its kind of hard to imagine that much pull from the stock 7afe, if thats what you've got
post Jan 9, 2004 - 2:03 AM
aaronc222
Joined Sep 22, '02
From Detroit
I don't notice any torque steer. If it gets too bad for you just get an LSD(Limited Slip Differential). The TRD one is $800+install or you can try calling Phantom Grip(they don't 'officially' make one for the Celica, but they can probably get you one that will fit).
post Jan 9, 2004 - 4:06 AM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
my car torque steers left, especially in the shift to second, it really pulls hard to the left, one time i ended up in the oposite lane when i wasnt paying attention
1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram
post Jan 9, 2004 - 5:09 AM
UT_Celica_GT
Joined Dec 9, '03
From Utah
I get a pretty harsh torque steer to the left shifting into second in my 5sFE GT
post Jan 9, 2004 - 8:33 AM
Dude, dont worry bout it, i know exactly what yoru talknig about. The car I had before my Celica was an 1984 BMW 318i, and when i started driving the Celi, even the 5sfe in it, it did what your talking about. Its not that bad you'll get use to the fact that your being pulled, not pushed. its nothing to worry bout.
post Jan 9, 2004 - 9:47 AM
kuya1284
Joined Nov 15, '02
From Corona & Vallejo, CA
Torque steer... are you guys serious? I never had this problem when I had my 7A... it doesn't even have that much torque to pull like that...
I'm going think about this one... just trying to understand what else could be causing this...
post Jan 9, 2004 - 11:13 AM
kuya1284
Joined Nov 15, '02
Ok.. I was thinking about this problem on my way to work... Now let me ask you guys this... when do you notice this problem? Does it happen WHILE you're holding the steering wheel? Or are you letting go lightly to see if it'll pull straight while accelerating?
The reason why is because I did notice something similar BUT after I lowered my car. When I let go of the wheel on the freeway... the car would drift... but if I accelerated... it would pull harder. Now if this is something that you're experiencing... this is NOT torque steer... your car is just misaligned.
Please provide more info guys...
post Jan 9, 2004 - 11:21 AM
LatinKraze
Joined Oct 22, '03
As soon as i take off from the red light, i hold on to the steering wheel, but it steers to the left. U gota sort of hold it in place. But you do notice a pull on the wheel when u floor it.
post Jan 9, 2004 - 6:54 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
QUOTE (kuya1284 @ Jan 9, 2004 - 4:13 PM)
Yeah you need an alignment, if it pulls when crusing, my just pull's when i hit the gas, and i can feel it in my hand, but i can easily hold it, its not like it takes any muscle.. yeah an my tread is fine, brand new tire, thanks to all that responded, I think im just not used to it yet all the way, but yeah not forkin over anymore money for a lsd, just using this as daily driver an saving up for another bimmer
post Jan 9, 2004 - 8:17 PM
Yeah its definately just the fact that your being pulled, not pushed.
post Jan 9, 2004 - 8:22 PM
macavely
Joined Nov 4, '02
this topic is strange to me cause if you car is aligned it shouldn't be doing that when you hit the gas.. unless you are slamming it down like a mad man..
post Jan 9, 2004 - 8:36 PM
LatinKraze
Joined Oct 22, '03
........Which is what i did. Lead foot syndrome kills my gas.
post Jan 9, 2004 - 11:53 PM
UT_Celica_GT
Joined Dec 9, '03
From Utah
that is the only time I notice it is when I'm driving really aggressivly. Usually when I'm racing. With my alignment if i let go on the highway I actually drift a little to the right. But I can tell that it's torque steer when I'm racin cuz it pulls pretty hard left, most noticably shifting into 2nd gear at excessivly high RPMs. So it's not my alignment. Cuz cruisin it pulls right, high RPM shift pulls left. It's not like huge and pulls my arm outta my socket, like digndoug said, but noticable.
post Jan 10, 2004 - 2:02 AM
The first time i really took the car out, from a stop sign i ripped into it and the car jerked left, and i was like whoa whats goin on. But there wasnt anything wrong. The only thing thats going to jerk ur car around is a flat tire. I realized it was just the difference between FWD and RWD.
post Jan 10, 2004 - 2:19 AM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE (kuya1284 @ Jan 9, 2004 - 6:47 AM)
my 7a does, lol.
in the 1-2 shift the boost spike up 1-2psi, making the most power just as the tranny hits 2nd gear
post Jan 10, 2004 - 2:24 AM
boosted_K2
Joined Aug 30, '02
From Michigan
get a wheel alignment. theres no way in hell you are torque steering the 7afe, or the 5sfe unless you are dropping them from over 5K RPM. even when hitting the gas its either tread wear, alignment, or tire pressures are off, check the tire pressures, then check your treadware, then get it aligned.
No but I don't buy it
Cause I'm...
Lo-Fi Version Time is now: June 24th, 2026 - 9:48 PM
