> Fuel filter being a pain...
post Aug 2, 2012 - 6:08 PM
Box
Joined Feb 23, '12
From Warrior, AL
Yes I searched and found the write up on it, but it barely made mention of the banjo bolt which is causing me nothing but grief. It won't break free. The top of the filter actually caved in before the bolt has given any. Have sprayed it with WD-40, still nothing. Have removed the air box out of the way so I have plenty of access. Using a 6 sided 17mm socket on a 1/2" drive ratchet, it's not slipping. Keeps flexing the filter. It is the ORIGINAL filter, so it's been in place for the last 17 years. Is this just a case of seized stubborn bolts, or is there something I'm overlooking? Don't like to be a bother, but I don't want to go any further and end up damaging the banjo bolt and line if there's something I'm overlooking. Changed the fuel pump strainer earlier, the fitting on the send line was a real pain. Finally got it to break free though. Here I thought the fuel filter was going to be the easy part... Thanks for any help that can be provided.
2001 Miata LS 5-speed
- Box   Fuel filter being a pain...   Aug 2, 2012 - 6:08 PM
- - rave2n   Nah, thats normal...soak it in PB blaster..it...   Aug 2, 2012 - 7:16 PM
- - delusionz   Yeah it's a right c*nt , for me its the bottom...   Aug 2, 2012 - 7:24 PM
- - Box   Alright, will get some PB Blaster then. Wasn...   Aug 2, 2012 - 7:36 PM
- - celica74   our fuel filters have the same problem hondas do. ...   Aug 3, 2012 - 11:48 AM
- - Box   Sadly I have no power tools. Always have been abl...   Aug 3, 2012 - 12:18 PM
- - Box   Why couldn't Toyota be cheap like Nissan and j...   Aug 3, 2012 - 12:23 PM
|- - Smaay   QUOTE (Box @ Aug 3, 2012 - 10:23 AM)...   Aug 5, 2012 - 11:07 PM
- - Box   Good news I found a breaker bar. Going to get som...   Aug 3, 2012 - 1:04 PM
- - gotian   easiest way i found was to remove the bracket from...   Aug 4, 2012 - 3:16 AM
- - celica74   Nissan filters suck. Until i went out and bought s...   Aug 4, 2012 - 9:32 AM
- - trdproven   soak it, if you need to. use two flare nut wrench...   Aug 4, 2012 - 6:28 PM
- - Box   Alright, after soaking if I still can't get it...   Aug 5, 2012 - 10:51 PM
|- - trdproven   QUOTE (Box @ Aug 6, 2012 - 1:51 PM) ...   Aug 5, 2012 - 11:37 PM
- - Box   If there's one thing I do before cranking on b...   Aug 6, 2012 - 12:38 AM
- - Box   Finally got it out, but the new one is being an eq...   Aug 6, 2012 - 4:23 PM
|- - rave2n   QUOTE (Box @ Aug 6, 2012 - 4:23 PM) ...   Aug 6, 2012 - 4:35 PM
- - gotian   To me the filter is cake to remove and install, no...   Aug 6, 2012 - 4:59 PM
- - Box   Finally got it on. The bracket isn't locked a...   Aug 6, 2012 - 5:56 PM
- - trdproven   its a pain to put back on, if you are trying to pu...   Aug 7, 2012 - 1:10 AM
- - Box   Will try and get everything back in its proper pla...   Aug 7, 2012 - 11:46 AM
Lo-Fi Version Time is now: August 31st, 2026 - 11:10 AM
