> A few ?? so i can finish up my 3rd gen swap!
post Aug 9, 2012 - 4:00 AM
MGCustoms325
Joined Feb 28, '08
From Miramar, Florida
Hi all,
Hopefully some of you that have completed your 3rd gen swaps will be able to help me ID a few things. If it makes a difference I am using a caldina IM on my 3rd gen 3S.
First, I need to ID what this hose goes to and what it does:
Where it is connected to the head
Next I need to ID this plug
And finally my mechanic wants to know what to use these for
And just to show my progress thus far:
Thanks!
Replies (1 - 7)
post Aug 9, 2012 - 4:06 AM
MGCustoms325
Joined Feb 28, '08
Almost forgot, How did you connect your dizzy to the coil? The wire is no where near long enough. I'm using brand new Toyota wires...
post Aug 9, 2012 - 8:07 AM
Neon90424
Joined Jan 19, '11
my 205 has 2 water pipes going to the TB then I cant really understand much of the other pics
post Aug 9, 2012 - 8:17 AM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
1. that hose your holding is the drain pipe on the factory st205 oil catch can (bottom nipple on black plastic container in pic)
2. that blue plug is the for the st205 turbo-vsv (solenoid in pic, bolts to bottom of st205 manifold)
3. got no idea, never had an st215
Mike W
269awhp / 273ft-lbs
post Aug 9, 2012 - 6:05 PM
delusionz
Joined Feb 11, '08
The vacuum ports can be pretty much anything, those ports your pointing to, on an st205 there is
Left side - brake booster, PCV port (ID6mm/OD8mm), Fuel reg (ID2mm/OD3mm)
Middle, back - Power steering idleup ID4mm/OD6mm
Middle, front - Map sensor port
Right side - Aircon idleup connects to pressurised port on IC ID6mm/OD8mm, BOV port ID4mm/OD6mm
Throttle body ISCV - Idle port ID12mm, 2x coolant ports (ID6mm/OD8mm)
Top of throttle body - 2x charcoal cannister ports
Mike W
269awhp / 273ft-lbs
post Aug 9, 2012 - 6:10 PM
delusionz
Joined Feb 11, '08
Are you planning to use the stock st205 ecu?
wondering how the plenum volume and runners compare to st205
Mike W
269awhp / 273ft-lbs
post Aug 9, 2012 - 6:33 PM
MGCustoms325
Joined Feb 28, '08
QUOTE (delusionz @ Aug 9, 2012 - 6:10 PM) *
Thanks for the reply. I will be running a c-one ecu.
post Aug 22, 2012 - 4:11 PM
pitcelica
Joined Jan 28, '07
From Québec, Canada
Here's some hint for the intake manifold ports :
The port #1 is the Idle Air Control Valve inlet. It should be connected with a hose to the air intake (somewhere between your air filter and the turbo compressor inlet).
The ports #2 are the coolant routing for the throttle body. It keeps the throttle plate from freezing under very cold condition by passing some hotter than ambient coolant around the throttle body. If you live in a hot climate and never see less than -20°C, you can keep them unplugged. Be sure to plug the corresponding nipples on the coolant pipes.
The port #3 was originally connected to the BOV. It's how I'm using it currently.
In your picture #5, you are pointing at the PCV valve intake manifold nipple. It should connect to the Positive Crankcase Ventilation Valve (PCV valve) that is located on the top of your valvecover.
Sam
This post has been edited by pitcelica: Aug 22, 2012 - 4:14 PM
Lo-Fi Version Time is now: September 15th, 2026 - 11:06 AM
