Aug 10, 2012 - 11:59 AM
Enthusiast ![]() Joined Mar 28, '10 From Milwaukee, WI Currently Offline Reputation: 3 (100%) |
Ok here goes. I recently had to do a complete rebuild of my 1998 toyota celica. From ground up i had my mechanic do the rebuild. Once i got the car back everything was running fine for awhile, but the mechanic told me that the ECU/ECM isn't reading and that i would need to get a new one. So i went and got a new ECU, and i still notice that my check engine light is still on, and the car is running a little funny. So Once i put the new ecu in i have it checked out and the individual at autozone tells me that there is a short somewhere in the electrical and that the ecu isn't reading.
Ok so i checked all my fuses and everything sees fine, but i still dont know exactly where to start looking for my problem. If any of you can help me lead me in the right direction it would be greatly appreciated. |
Aug 10, 2012 - 12:03 PM
edit: would like to note the car does start and run. again if someone could enlighten me that would be great
Aug 10, 2012 - 12:06 PM
So the light is on, but they can't pull any codes?
Aug 10, 2012 - 12:14 PM
The code that their giving me is ECM B is the only definition i got from them. and the mechanic gave me a DTC P1600 ECM BATT Malfunction.
Aug 10, 2012 - 1:59 PM
http://www.parksoffroad.com/tacomamods/mai...ode/cip1600.pdf
Seems to be some good information there, if you haven't read that already. It's not for a 5S specifically, but it's still good info. This post has been edited by richee3: Aug 10, 2012 - 2:00 PM -------------------- "Employ your time in improving yourself by other men's writings, so that you shall gain easily what others labored hard for." -Socrates. Even Socrates told us to use the search button!
Aug 10, 2012 - 3:23 PM
Thanks for the info, so possible the power line to the ecu is bad. i guess ill that out and test to see if there is voltage to the line.
Aug 10, 2012 - 5:07 PM
ok update. found that the main power wire to the ecu was dead. rerouted another power source and the check engine light went off. now pulled the two fuses that run the ecm and efi and waiting for 15 min and putting them back in and seeing how that works. thanks for everyone's help! Hoepfully i have everything solved.
| Lo-Fi Version | Time is now: August 31st, 2026 - 1:23 AM |
