> starting troubles
post Aug 10, 2012 - 3:18 PM
perkyshadow
Joined Nov 13, '10
From Greenville, SC
I need some ideas, guys. My '96 hatchback is having some starting issues. It was running flawlessly, and I left it in a lot for sale at my mom's work about three weeks ago. Now it just won't start. I checked the starter and battery. They're fine. I also checked the clutch start wire just to make sure it's connected. When I go to crank it, I can hear the fuel injectors engage. But it just won't activate the starter. No wiring has changed since I was driving it every day. All the ground wires are properly connected. No grounds are loose. I did just put the engine in this past March. It acts like it did before I remembered to connect the clutch start wire. Any ideas? Could it be the ignitor or something? I'm a little at a loss! Thanks in advance!
- perkyshadow   starting troubles   Aug 10, 2012 - 3:18 PM
- - SupraKid   You are sure the battery is fully charged?   Aug 10, 2012 - 3:27 PM
- - perkyshadow   Yeah. I took it to Autozone and had them charge i...   Aug 10, 2012 - 4:39 PM
- - richee3   Any clicking, popping, any noises like that when y...   Aug 10, 2012 - 4:55 PM
- - Ghost1   i had this happen to me before, the connector at t...   Aug 10, 2012 - 4:58 PM
- - perkyshadow   No popping or clicking. The starter does nothing ...   Aug 10, 2012 - 11:59 PM
- - SupraKid   Since you have a GT you can hotwire the starter pr...   Aug 11, 2012 - 1:25 PM
- - Special_Edy   QUOTE (Special_Edy @ Apr 3, 2012 - 1...   Aug 11, 2012 - 3:05 PM
- - zfjohnson07   check your fuses, i had this problem when i tried ...   Aug 11, 2012 - 7:49 PM
- - perkyshadow   Thanks for the insight, guys! I didn't sp...   Aug 11, 2012 - 11:28 PM
- - gotian   From someone who worked art auto zone I will tell ...   Aug 12, 2012 - 12:32 AM
- - travisxcore   Test your AM2 fuse. My car died while driving it a...   Aug 12, 2012 - 1:41 AM
- - Special_Edy   No travisxcore, I think you were right at first. T...   Aug 12, 2012 - 3:01 AM
- - perkyshadow   Well.... I checked it out today. Got it started ...   Sep 7, 2012 - 10:43 PM
- - Special_Edy   The idiot lights are grounded to the engine and th...   Sep 7, 2012 - 11:09 PM
- - richee3   Sounds like something is unplugged somewhere. The ...   Sep 8, 2012 - 5:59 AM
- - zfjohnson07   You don't have a car alarm do you? When I boug...   Sep 8, 2012 - 6:57 AM
- - perkyshadow   Thanks for the help guys! I also spent a litt...   Sep 8, 2012 - 10:40 PM
- - richee3   Glad you got it fixed!   Sep 9, 2012 - 7:05 AM
- - Special_Edy   RE: starting troubles   Sep 9, 2012 - 6:48 PM
Lo-Fi Version Time is now: June 25th, 2026 - 9:58 AM
