Aug 13, 2012 - 10:10 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Mar 7, '10 From Ft. Lauderdale Currently Offline Reputation: 9 (100%) |
1996 celica gt auto
181,000 miles replaced/installed: 2 years ago: -both front rotors/calipers/pads -two way remote start/keyless entry. (two-way means the remote will tell you if the alarm is going off, or if the car is locked, etc) last year: -battery -front driverside wheel bearing (hub and spindle) -trans fluid flushed -coolant flushed -thermostat earlier this year -flex pipe near down pipe was replaced -new cat -both rear calipers/rotors/pads -all 6 speakers replaced -valve cover gasket -accessory belt -plugs, wires, distributor cap & rotor -kyb shocks/eibach springs. BAD: -front driver side cv boot is ripped -power antenna doesn't work -there is rust on the passenger side rear fender, and on the passenger side door. (i have a silver rust free door that can come with the car if wanted) I feel that a $2200 asking price is fair, due to the fact that since last November, I have put over that much into the car fixing everything that needed fixing. (till the cv-boot tore) here is my craigslist add: http://chicago.craigslist.org/wcl/cto/3238552447.html thanks for looking, -Zach This post has been edited by Zake: Sep 3, 2012 - 12:15 PM -------------------- |
Aug 17, 2012 - 2:49 PM
Bump
Aug 25, 2012 - 11:01 PM
Saturday night bump
Aug 29, 2012 - 11:10 PM
reduced price bump
| Lo-Fi Version | Time is now: August 24th, 2026 - 9:45 PM |
