> car feels different
post Aug 17, 2012 - 7:34 PM
MangJavs
Joined Jun 27, '12
From Dallas
Car is at 200,000 and I feel a difference in the way it runs, it doesn't accelerate smoothly or switch gears smoothly even though its an automatic and even when I brake my car is rocking back an forth on the way to a stop. What seems to be my problem, should I just change the spark plugs?
post Aug 17, 2012 - 8:11 PM
pandakid
Joined Feb 12, '06
From Fresno CA
when you break does the steering wheel shake alittle back and foward?if it does sounds like you need new breake pads and break rotors
post Aug 17, 2012 - 8:16 PM
mkernz22
Joined May 10, '10
From MA
get an alignment. you might need ball joins and outer tie rods. as far as acceleration, change the plugs and wires, replace your o2 sensor, oil change, change the transmission fluid or see if it is low because that would be the cause of hard shifting. your engine mounts might have gone as bad as well.
post Aug 18, 2012 - 2:07 AM
MangJavs
Joined Jun 27, '12
From Dallas
How much is the sparkplugs and the wires worth ?? By wires you mean the one that connects to the plugs right?
post Aug 18, 2012 - 11:35 AM
mkernz22
Joined May 10, '10
From MA
Spark plugs should be about $10, not sure about the wires since I've never bought any, and yes, the wires that go from the distributor to the spark plugs
post Aug 18, 2012 - 10:14 PM
ILoveMySilly97
Joined Mar 8, '12
From Hanford/Fresno, Ca
QUOTE (MangJavs @ Aug 18, 2012 - 3:07 AM) *
People(like myself) recommends "NGK" spark plugs and wires for high quality but the autozone ones are much cheaper and gets the same job done with a CHEAPER drive.
post Aug 19, 2012 - 9:50 AM
trdproven
Joined Aug 2, '05
From Guam
your problem can be anything, i suggest, specifying particular symptoms, where its coming, etc.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Aug 19, 2012 - 5:42 PM
dudeofchaos
Joined Dec 9, '08
From Blainville
Could be 1 single thing, like it could be many things causing all this.
I would say give your car a nice tune up (Engine oil, tranny oil, air filter check, fuel filter, spark plugs and wires, distributor..) Also maybe your engine mount(s) could be shot and causing things to be not a smooth as they should.
It can affect the acceleration (like i believe it does on mine), and changing gear might not be as smooth either (for man. trannies).
Otherwise you should make it inspected by a mecanic or give us more specific details.
Lo-Fi Version Time is now: August 31st, 2026 - 9:17 AM
