> 7afe engine swapped so slow, new egnine slow
post Aug 20, 2012 - 3:37 AM
huntsmcgee
Joined Jul 24, '12
From north carolina
HI, so i just got my engine for my car and its been years since i had it running and it just seems so slow. i know the 0-60 for a st auto is like 9-10 secs but i think it would take like over 15 i check my timing using a light and it matched 10* could it be 180 off it it alings with the markings and if not what could be making it so slow
Replies (1 - 6)
post Aug 20, 2012 - 7:14 AM
Restriction in the intake somewhere, check the air filter piping and the filter itself. Exhaust leaks meaning lack of backpressure, vacuum leaks, faulty plugs, wiring, or fuel injectors...the list goes on.
'90 MX-5 Mariner Blue
'15 Optima Grey
'04 206 GTi silve
post Aug 20, 2012 - 11:47 AM
celica74
Joined Feb 8, '10
From North Carolina
i hate myself for saying this, but its a 7a, cant expect much.
post Aug 20, 2012 - 11:57 AM
HectortheRican
Joined Dec 26, '09
From Albuquerque, NM
Check if you're knock sensor is working. If it isn't, your ECU is retarding timing about 10-15 deg and the car will feel super sluggish.
June '12 COTM
'95 AT200
post Aug 20, 2012 - 7:25 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
Is the trans starting in first gear?
post Aug 20, 2012 - 8:30 PM
huntsmcgee
Joined Jul 24, '12
From north carolina
Thanks for the replays. i should have gave more info. The car has a ebay header had it for years and before the swap. it has a k@n intake filter and pipe brand new. also has new spark plugs. It has a code thrown that says egr malfunction but maybe its the header. And how do i check if the sensor is workin
post Aug 21, 2012 - 9:57 PM
Hanyo
Joined Aug 16, '03
From Bay area
engine is probably in limp mode due to the engine throwing a code.
Lo-Fi Version Time is now: August 29th, 2026 - 4:25 PM
