> Trans issue
post Aug 20, 2012 - 10:31 AM
mi645
Joined May 23, '12
From northridge,CA
Hello I have a 99 celica gt with only 95k miles when I bought at up until now I had this problem getting into gear at a full stop I'd clutch in and the shifter would be difficult to put it into gear very difficult it would click twice but u wouldn't feel the trans clucking or anything and when u drive it shifts just fine now I've replaced oem clutch slave and master and new fluid in the master cylinder bleeded the system and also changed the trans fluid and im still having this issue any ideas?
- mi645   Trans issue   Aug 20, 2012 - 10:31 AM
- - njccmd2002   cluthc?   Aug 20, 2012 - 10:41 AM
- - mi645   I haven't replaced the clutch but is there a w...   Aug 20, 2012 - 10:46 AM
- - Special_Edy   It sounds like the syncronyzers. Drain your transm...   Aug 20, 2012 - 10:57 AM
- - mi645   Ok then I will try as u said u better be right I d...   Aug 20, 2012 - 11:17 AM
- - BonzaiCelica   i'm having issues. I just replaced my car with...   Aug 23, 2012 - 5:45 AM
- - mi645   This sounds like the problem I am having also? But...   Aug 23, 2012 - 7:15 AM
|- - BonzaiCelica   QUOTE (mi645 @ Aug 23, 2012 - 8:15 A...   Aug 23, 2012 - 2:53 PM
- - mi645   Honestly I changed the tranny fluid the clutch mas...   Aug 23, 2012 - 5:13 PM
|- - BonzaiCelica   QUOTE (mi645 @ Aug 23, 2012 - 5:13 P...   Aug 23, 2012 - 5:46 PM
|- - SwissFerdi   QUOTE (mi645 @ Aug 23, 2012 - 6:13 P...   Aug 23, 2012 - 5:51 PM
- - malecrod   Had the same anoying problem that persisted even a...   Aug 23, 2012 - 6:57 PM
- - BonzaiCelica   currently have a 95 camry s54 transmission cable. ...   Aug 23, 2012 - 8:04 PM
- - richee3   Round numbers, 52".   Aug 23, 2012 - 8:17 PM
- - BonzaiCelica   really the longer s54 cable from the 94-99 celica ...   Aug 23, 2012 - 9:09 PM
- - richee3   "Round numbers" means it's close eno...   Aug 23, 2012 - 9:28 PM
- - BonzaiCelica   sorry for sounding real paranoid I just don't ...   Aug 23, 2012 - 9:53 PM
- - mi645   From driving exp I was sure that it's not the ...   Aug 24, 2012 - 2:06 AM
|- - BonzaiCelica   QUOTE (mi645 @ Aug 24, 2012 - 3:06 A...   Aug 24, 2012 - 2:40 AM
- - mi645   Didn't know u can use beams parts for our 5sfe   Aug 24, 2012 - 3:40 AM
- - BonzaiCelica   http://www.6gc.net/forums/index.php?showto...61995...   Aug 25, 2012 - 1:47 AM
- - Ted95   my coupe is having issues as well. my s54 will go ...   Aug 27, 2012 - 11:50 AM
|- - mkernz22   QUOTE (Ted95 @ Aug 27, 2012 - 12:50 ...   Aug 27, 2012 - 6:15 PM
- - BonzaiCelica   yea more than likely yes. Read the first page. the...   Aug 27, 2012 - 9:16 PM
|- - Ted95   QUOTE (BonzaiCelica @ Aug 27, 2012 - 10...   Aug 27, 2012 - 11:18 PM
- - BonzaiCelica   got a question regarding clutch pedal adjustment. ...   Aug 28, 2012 - 11:20 PM
- - trdproven   .   Aug 29, 2012 - 6:03 PM
- - trdproven   QUOTE (Ted95 @ Aug 28, 2012 - 2:18 P...   Aug 29, 2012 - 6:07 PM
- - BonzaiCelica   here's the scenario: car's at a dead stop...   Sep 15, 2012 - 2:05 AM
- - Stambo   did you do a oem clutch master? I've replaced ...   Sep 15, 2012 - 9:08 AM
- - BonzaiCelica   my next thought was go with a napa clutch slave cl...   Sep 17, 2012 - 12:50 AM
- - Smaay   have you checked all the cables and linkage? whats...   Sep 17, 2012 - 12:24 PM
|- - BonzaiCelica   QUOTE (Smaay @ Sep 17, 2012 - 12:24 ...   Sep 17, 2012 - 12:31 PM
- - BonzaiCelica   now my car wont even go into 2nd, 4th, or Reverse ...   Sep 19, 2012 - 11:28 PM
Lo-Fi Version Time is now: September 15th, 2026 - 2:42 PM
