3 Pages V   1 2 3 >
> Conversion: 100 to 114, Questions (REAR)
post Aug 24, 2012 - 6:27 PM
smkr3w
Joined Nov 29, '10
From Lake Havasu City, AZ
Alright, so my passenger side rear hub seems to be 'bent' or at least it's not centered correctly. And I was looking to replace them with my friends assistance but have an itch to address.
In the discussion of this thread HERE. It was said that the xv10 Camry's rear hub/bearing assembly can bolt onto the Celica's rear; which would mean the rotors would have to be re-drilled to 5x114 to mate with the new hub. Correct?
On eBay:
94-99 Celica Rear Hub/Bearing Assembly- $230
91-96 Camry Rear Hub/Bearing Assembly- $66
I figured since the price difference is relatively large. Than I should go the conversion route smile.gif
Then I wondered if I can buy rotors for a xv10 Camry, would they fit the stock brake caliper?
Upon searching I found this info (unconfirmed):
--------------------------------- 94-99 Celica -------- 91-96 Camry -----
Outside Diameter:-------------- 269mm ----------------- 269mm ---------
-------------Height:------------ 64.6mm ---------------- 64.9mm --------
---------Nom Thick:------------ 8.9mm ----------------- 10mm ----------
----------Min Thick:------------- 8mm --------------------- 9mm -----------
-------Bolt Pattern:------------ 5x100 ------------------- 5x114 ----------
So with such a small difference in Thickness, while still having the same overall Diameter, Would it be possible to utilize the Camry's rear rotor as well?
Can anyone weigh in here?? I really need to fix my rear, because sounding like a wooden rollercoaster is getting old tongue.gif
This post has been edited by smkr3w: Aug 24, 2012 - 6:40 PM
post Aug 24, 2012 - 7:03 PM
Syaoran
Joined Jan 4, '12
From US
Personally I would drill the Celica rotors. Machine shop shouldn't charge you much for it. I would do so mainly because the caliper would have to "bite" further in for the pads to grab onto the rotor.
If it's not a concern however then the camry rotors would be the best, and next up would be a front hub conversion with Rav4 hubs and camry rotors I believe.
A thing to check is if the rear Camry rotors have the e-brake shoes in the same location as the Celica.
1993 Celica GT Coupe - sold
1994 Celica GT Liftback
post Aug 24, 2012 - 7:10 PM
smkr3w
Joined Nov 29, '10
Nice! The fronts will come later.. I just need to fix the rears ASAP. So I figured if its cheaper to convert, why not kill two birds with one stone biggrin.gif
post Aug 24, 2012 - 7:29 PM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
5x114 would be awesome for wheel fitment options
Mike W
269awhp / 273ft-lbs
post Aug 24, 2012 - 7:48 PM
Sorry but the argument syaoran makes is worthless...youd go with celica rotors cause the caliper would have to bite?
The rotor thickness difference is basically given up in pad wear...
Thats not the issue
The rotor hat spacing and offset are what make the rotor usable or unusable..
post Aug 25, 2012 - 3:28 AM
smkr3w
Joined Nov 29, '10
Thanks. Either way this is why I'm posting.. so I can know, before I spend money on something I can't use.
Still, redrill and camry hubs is cheaper than replacing with celica ones.
Plus 5x114 wheel options!
post Aug 25, 2012 - 3:35 AM
yellowchinaman
Joined Aug 11, '08
From London
hold up! Are we forgetting that if you change your bolt pattern then your disk wont fit as well?
post Aug 25, 2012 - 3:58 AM
smkr3w
Joined Nov 29, '10
QUOTE (yellowchinaman @ Aug 25, 2012 - 1:35 AM) *
Not sure I understand? You mean the brake discs? Those will be taken to a machine shop to re-drilled to fit 5x114. We're talking rears here..
In the thread I linked above its been discussed that the front can be swapped with Rav4 hub and Camry discs for direct bolt. but that is for later, I'm focusing on the rears for the time being.
post Aug 25, 2012 - 10:30 AM
Syaoran
Joined Jan 4, '12
From US
I'm assuming you have universal wheels right? 5x100/5x114.3
post Aug 25, 2012 - 1:55 PM
smkr3w
Joined Nov 29, '10
QUOTE (Syaoran @ Aug 25, 2012 - 8:30 AM) *
post Aug 25, 2012 - 2:49 PM
Syaoran
Joined Jan 4, '12
From US
QUOTE (smkr3w @ Aug 25, 2012 - 2:55 PM) *
I was about to do it on mine but I decided it was easier and simpler to just press out and in a new bearing. Cost me $20 to have it done by my mechanic. Had to cut off a piece that got stuck to the hub thanks to the heat produced by the grinding bearings. Pressed the hub back in and impacted a new axle nut to the back. All is good.
post Aug 31, 2012 - 2:59 AM
smkr3w
Joined Nov 29, '10
Got a Rear Camry Rotor today, so I can find out for myself whether or not I can make the rear hub conversion bolt on instead of needing some machining.
Main reason for this is because I checked with a local machine shop, and they want $35 PER ROTOR to re-drill and bore from 5x100 / 54.1 to 5x114 / 60.1 to fit the Camry hub. So that'd be $70 for just re-drilling my old rotors, the Camry rotor that I just received only cost me $20 shipped..
I will be ordering the rear hubs soon regardless of the outcome.. It'll all be worth it for wheel selection biggrin.gif
This post has been edited by smkr3w: Aug 31, 2012 - 3:01 AM
post Oct 4, 2012 - 7:03 AM
ST204R
Joined May 27, '08
From Oz
Did this go ahead? And if so did your celica handbrake setup work with the camry disc?
I'm looking at doing the same thing so I can swap my rear brakes to camry and front brakes over to the 2008 highlander front brakes for a big cheap upgrade.
Cheers
This post has been edited by ST204R: Oct 4, 2012 - 7:05 AM
1MZ-FE 3.0L QUAD CAM V6
E153 5SPD MANUAL
GT4 FRONT END
post Oct 30, 2012 - 8:58 PM
smkr3w
Joined Nov 29, '10
QUOTE (playr158 @ Aug 24, 2012 - 5:48 PM) *
This was my biggest concern, and the reason why I only bought one rotor to test.
anyway.......
SUCCESS!
Stock CELICA rear hub/bearing assy. top
Replacement CAMRY rear hub/bearing assy. bottom
..And CAMRY rear ROTOR, fits like a glove!
So bottom line-
So why do this conversion?
-Wheel Options!
-Cheaper than Celica Replacement Parts
post Oct 30, 2012 - 9:04 PM
richee3
Joined Jun 29, '08
From Denver
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Oct 30, 2012 - 9:32 PM
so front hubs and back hubs do interchange... great find.
post Oct 30, 2012 - 9:58 PM
Syaoran
Joined Jan 4, '12
From US
Wow someone sticky this!!!
Rav4 Front Hubs/Camry front rotors and Camry Rear Hubs and Rotors for a full 5x114.3 conversion? Awesome!!
post Oct 30, 2012 - 11:47 PM
but with the FRS now in the market
the 5 x 100 wheel selection will be better
post Nov 16, 2012 - 4:35 PM
frotou
Joined Jan 9, '04
From Quebec city, Quebec, Canada
5x114.3 wheel selection is awesome !!!!!!!! + used selection also .
Let's do the front !!
post Nov 16, 2012 - 4:50 PM
smkr3w
Joined Nov 29, '10
^ another member here has already done so using a Rav4 front hub and camry discs! CLICK HERE
3 Pages V   1 2 3 >
Lo-Fi Version Time is now: September 8th, 2026 - 3:03 PM
