Aug 24, 2012 - 9:07 PM
Enthusiast ![]() ![]() Joined Jan 13, '12 From Georgia Currently Offline Reputation: 3 (100%) |
So about 2 months ago I Bought a 97 GT liftback. It is my 3rd Toyota(hence the username) I have a 93 Corolla that I have recently had a bunch of paint and body work done to a 96 Corolla and now my 97 GT
So far my plans are to beef it up a little bit. Mostly by just unclogging it what I've done so far: KYB GR-2 all the way around Slotted and drilled rotors Ceramic Pads New Valve Cover gasket (painted black while I had it off cleaning New oil pan Gasket Thorough cleaning of the engine and bay( still not quite satisfied will most likely make another pass) Weapon R Dragon series SRI Functional Sharkfin Antenna conversion Reverse Glow Gauges (Black Face) 7th Gen short throw with a black suede blue stitch boot 17" Enkei Performance GW8 wheels Twin piston calipers from a 94 camryV6 Future plans Include: High Flow cat High Flow cat delete/resonator Dual exhaust Will probably use a set of aftermarket side mirrors with LED turns built in Projectors in lows and highs with Amber led strips for turns inside the housings. Going to go through the retrofit source for the projectors Pakfiefer skirts and rear Most likely an invader style front bumper ![]() ![]() ![]() ![]()
This post has been edited by toyota123: Nov 7, 2013 - 1:58 PM -------------------- 97 Celica GT liftback DD/ project
96 corolla back up DD |
toyota123 My 97 GT Aug 24, 2012 - 9:07 PM
zfjohnson07 damn clean! Aug 25, 2012 - 8:27 PM
toyota123 Thanks used engine block enamel on the valve cover... Aug 25, 2012 - 10:05 PM
toyota123 Recently upgraded my door panels. Found a totaled ... Oct 20, 2012 - 10:18 AM
richee3 Great progress so far! Looks like a good clean... Oct 20, 2012 - 11:43 AM
toyota123 The 96 is my alternative driver and is absolutely ... Oct 21, 2012 - 8:08 AM
toyota123 Q Oct 21, 2012 - 6:12 PM
toyota123 Been away for a while but this is what's been ... Aug 8, 2013 - 2:37 PM
toyota123 Then I got my insurance check came in and here is ... Aug 8, 2013 - 2:42 PM
Kaiser I was never much a fan of matte black paint jobs, ... Aug 8, 2013 - 4:10 PM
toyota123 Ty
It's been a lot of hard work just can't... Aug 8, 2013 - 5:04 PM
Overkill QUOTE (toyota123 @ Oct 20, 2012 - 3... Aug 8, 2013 - 10:57 PM
toyota123 Close up of the new wheels repainted the caps. Th... Aug 22, 2013 - 11:56 AM
The_enD Looking good.
I've always wanted a matte black... Aug 22, 2013 - 12:45 PM
toyota123 Painted and installed twin piston calipers of a 94... Sep 11, 2013 - 1:17 PM
toyota123 Just a little update
Got the axle seal fixed, al... Sep 21, 2013 - 9:47 PM
toyota123 Well it happened again. This time I lost a fight ... Nov 7, 2013 - 1:57 PM
Keiri Ouch!
I take it you're safe and sound? I ... Nov 7, 2013 - 2:13 PM
toyota123 Yeah I'm OK surprisingly I was a little sore f... Nov 7, 2013 - 2:21 PM
Kaiser QUOTE (toyota123 @ Nov 7, 2013 - 3:2... Nov 9, 2013 - 7:32 PM
toyota123 Thanks for the concern and support.
I'll kee... Nov 10, 2013 - 5:56 PM
samboo QUOTE (toyota123 @ Nov 10, 2013 - 6... Nov 17, 2013 - 4:47 PM
toyota123 I think I may have found a suitable replacement. I... Nov 21, 2013 - 11:51 AM![]() ![]() |
| Lo-Fi Version | Time is now: August 11th, 2026 - 10:26 AM |
