Aug 26, 2012 - 4:59 PM
Enthusiast Joined Jul 21, '12 From FL Currently Offline Reputation: 0 (0%) |
Sigh.
I got back in the car after lunch yesterday, turned the ignition key, and heard a single click. My first thought was the battery but a jump left me with a single click. Must be the starter then... Nope. Three starters later I'm still getting a single click. Battery voltage is 12.53 and drops to 11.5 when I try to start the car. If I'm hearing the solenoid from the starter and can feel the click, is the issue down to the 4 gauge wire? I've read: http://www.6gc.net/forums/index.php?showto...&hl=starter but I'm still scratching my head. |
n47pt Not Starting! Aug 26, 2012 - 4:59 PM
trdproven did you check if you get spark? that would be the... Aug 26, 2012 - 5:16 PM
mindkiller If its an automatic it might be the safety switch. Aug 26, 2012 - 5:43 PM
n47pt I'm not even turning the engine over at this p... Aug 26, 2012 - 5:44 PM
mindkiller QUOTE (n47pt @ Aug 26, 2012 - 6:44 P... Aug 26, 2012 - 5:48 PM
n47pt QUOTE (mindkiller @ Aug 26, 2012 - 5... Aug 26, 2012 - 5:57 PM
mindkiller hmmmm like u said the one click make u think its t... Aug 26, 2012 - 6:03 PM
n47pt I just tested the 4 gauge cable and it's deliv... Aug 26, 2012 - 7:29 PM
mkernz22 did you try hitting the starter at all with a mall... Aug 26, 2012 - 7:42 PM
zfjohnson07 i know this sounds dumb but put it in neutral, try... Aug 26, 2012 - 8:38 PM
199celica Not to make a bad experience worse but try to put ... Aug 26, 2012 - 11:57 PM
n47pt QUOTE (mkernz22 @ Aug 26, 2012 - 7:4... Aug 27, 2012 - 1:19 AM
Bitter I've had new rebuilt starters be sticky the fi... Aug 27, 2012 - 7:43 AM
n47pt I bypassed everything this morning to see if the s... Aug 27, 2012 - 10:28 AM
Special_Edy Loose battery clamp. Make sure the clamp is tight,... Aug 27, 2012 - 10:51 AM
n47pt I'm sad to say that I'm out of ideas and I... Aug 27, 2012 - 8:56 PM
zfjohnson07 well talk to special_eddy he is smart at this. but... Aug 27, 2012 - 9:16 PM
trdproven check the resistance of all the starter wires. di... Aug 27, 2012 - 11:51 PM
n47pt Fixed!
The positive end of my battery is conn... Aug 28, 2012 - 5:33 PM
trdproven good job! if u had a capacitor it may give yo... Aug 28, 2012 - 10:18 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 23rd, 2026 - 10:16 AM |
