> Interested in HID's and
post Aug 29, 2012 - 6:26 PM
cyb593
Joined Feb 22, '04
From USA
I was looking at ddmhid and i see on the site they have like 5 different kits. I was thinking about the bixenon kit. Is this the right kit or does it matter? Which number for color is the brightest or does it not matter? Should i upgrade to 55w? What about the relay harness/LBF modules? Also can i use the same balasts for high beams too? Sorry i am new to HID's and anything you can tell me will help me lots.
post Aug 29, 2012 - 7:02 PM
Zimluura
Joined Feb 3, '05
From USA/Virginia
here is what i've always heard about hids.
1) almost always illegal to convert to them in the united states. the whole lens has to be dot approved for hid use. i think there is one place that sells a whole round headlight unit that is dot approved; but it isn't for our cars specifically. places in the us that sell them say they are for offroad use only, thus removing them from dot's jurisdiction.
2) cars that come with them have lenses that dot approves of for use with them. but even then they don't use them in their hi-beams, because the on/off nature of hi-beams doesn't work well with hid. whether it degrades them quicker or there is a warmup i don't know.
3) i am not a lawyer, but...you can always say it was there when you bought the car if you wind up in court. if you get something really intensely blue or purple you are probably more likely to get ticketed.
4) i think jdm projector lenses are better than usdm lenses if you run hids, but i could be completely wrong on that.
5) could be difficult to pass inspection with them. not really sure.
post Aug 29, 2012 - 7:16 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
ive gone 4 years with HID's in my oem lights without any problem
エキサイティングカーレーシングチーム!
post Aug 29, 2012 - 7:26 PM
richee3
Joined Jun 29, '08
From Denver
As a general rule, lower Kelvin ratings produce more usable light. Usually, 4,300-4,500K is the whitest light and 12,000K is purple and difficult to see with at night. 3,000K is yellow.
Don't go for the 55w upgrade. The general consensus is that the light output is marginally better than the 35w kits but it's so much hotter that it cooks the insides of your headlights.
HID's have a warmup and cool down period, making them usually unsuitable for high beam/fog light applications, unless you never use your brights.
You really should go for the harness, as the ballasts are not part of the car's electrical system.
Last, and by far most importantly, you really shouldn't put HID's in factory USDM headlights. These headlights were designed to scatter light and with HID's, you scatter intensely bright light into oncoming traffic. JDM projectors are better at controlling the light, provided you have fixed the cutoff. Granted, we've all broken these rules and gotten away with it but it's still irresponsible. I did it and never caused any accidents but I did make plenty of people mad.
Edit: The issue with HID's and the stock headlights is that the focal point is different between HID's and standard halogen bulbs. The bulb itself doesn't sit in the same place inside the headlight and therefore, the light housing can't control the light output properly. A much better option are a new type of bulb called HIR's. Same light output as LED's, yet it's the same style bulb as a regular halogen bulb so your housings control the light much better. Plus they cost about the same as a DDM kit, and they don't have a warmup or cool down period so they're great for high beams and fog lights.
This post has been edited by richee3: Aug 29, 2012 - 7:49 PM
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Aug 29, 2012 - 9:37 PM
jordisonjr
Joined Jan 20, '09
From Winnipeg
QUOTE (Zimluura @ Aug 29, 2012 - 7:02 PM) *
DOT has absolutely nothing to do with HIDs.
My Celica has the exact same headlight housigns as yours in the states but they are DOT approved, and really I shouldn't have HIDs in them.
DOT is simply a standard.
HID's really shouldn't be installed in headlight housings that are non projector housing (all OEM celica housings, DOT or not), and only in retreofitted projectors or JDM projectors.
My Celica!
post Aug 30, 2012 - 1:29 AM
Zimluura
Joined Feb 3, '05
From USA/Virginia
this link seems to be in line with most of the research i've done.
http://orca.st.usm.edu/~jmneal/tiburon/hids.htm#9
post Aug 30, 2012 - 5:07 AM
cyb593
Joined Feb 22, '04
From USA
Thanks for all the information on HID's. The thing that i find it B.S. is that i run into newer vehicles with HID's that blind the hell out of me and they are factory. How is this any different from me doing the same with aftermarket equipment? I will look into my other options and see what i can find. My lights are just to dim compared to 90% of the cars in atlanta. I live on a street with no street lamps so i mean it is pitch dark and i need to be able to see a decent distance in front of my vehicle.
post Aug 30, 2012 - 10:32 AM
Zimluura
Joined Feb 3, '05
From USA/Virginia
i hear you man!
there is a wrx around here with purple beams that are aimed way too high, i guess the law is supposed to stop that, but if he's not getting gigged for it, then the laws only stop people who do the research to convert to hid safely.
i think i've heard mixed things about the sylvania silver stars, that might be something to look into.
post Aug 30, 2012 - 10:52 AM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
I recommend silver stars if you dont want to go with HID's.
From what I remember (its been years since I had them) they were a decent amount of $
Had a nice white color, and where VERY bright and long lasting
エキサイティングカーレーシングチーム!
post Aug 30, 2012 - 11:00 AM
cyb593
Joined Feb 22, '04
From USA
i was looking around and i saw the phillips chrystal vision ultras which are supposed to be really good i am going to give those a try. Thanks for the info, if these dont produce enough light i might just have to pull some illegal shenanigans.
post Aug 30, 2012 - 11:05 AM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
Sylvania vs Sylvania Silverstar Ultra
This post has been edited by Special_Edy: Aug 30, 2012 - 11:20 AM
post Aug 30, 2012 - 12:10 PM
richee3
Joined Jun 29, '08
From Denver
Silverstars tend to blow out often and my experience with them proved that a 65w 9005 bulb in place of a 9006 Silverstar was far brighter. Wasn't exactly the smartest thing to put that much of a draw on wires designed for 55w, but I ran that way for years with no issues. Then again, HID's put a much more sudden draw on the electrical system than the 65w bulbs do.
1998 Celica GT-
BEAMS Swapped.
post Aug 30, 2012 - 4:59 PM
ILoveMySilly97
Joined Mar 8, '12
From Hanford/Fresno, Ca
What I did was installed 8k HID kit for my lo-lights and bought 3k halogen bulbs for my hi-lights and fog-lights. My hid kit was was unbrand from a local store and my halogen bulbs were from an eBay user. The brand was called HiproPower. Never had a problem with both of them. Had them on for at least 4 months now. My fog lights are always on when I have my lo-lights are on. BUT over all I'd say the projectors are the best way to go if you had that 600+ money. Lol. And I don't know anything about being DOT approved but I know the projectors are NOT DOT approved. smile.gif
post Aug 30, 2012 - 6:34 PM
Special_Edy
Joined Oct 29, '11
I couldnt imagine in a million years that someone would disassemble my car to check if my headlamps were DOT stamped or not. They dont even check the headlight alignment here in texas
post Aug 30, 2012 - 7:21 PM
Bigblock
Joined Feb 14, '09
From Mid West
So far, happy with the silverstars--
Over a year and no problems.1.
post Aug 30, 2012 - 7:42 PM
trdproven
Joined Aug 2, '05
From Guam
QUOTE (cyb593 @ Aug 30, 2012 - 9:26 AM) *
DDM kits are pretty good for its price and its supposed lifetime warranty. I believe the bixenons are for lamps that have both low and high beam filaments in one bulb, in your case no, its separate. for the 55watts are unnecessary, they are only somewhat brighter not noticeable to the human eye, unless you put a 55w on one side and 35 in the other. and its been said there are some electrical issues. 35 watts is more than enough. just remember hids settle into 35 watts once its warmed up which is lower than stock at 55w, but at startup it pulls initial crazy wattage so imagine it at 55watts pulling at starting is way over 100w.
QUOTE (Zimluura @ Aug 30, 2012 - 10:02 AM) *
HIDs should only be run in projector lamps, thats how it comes out of the factory, and the light comes out more normal, than non-projectors, the light output is uncontrolled and just goes everywhere, it stupid.
QUOTE (richee3 @ Aug 30, 2012 - 10:26 AM) *
AGREED
QUOTE (jordisonjr @ Aug 30, 2012 - 12:37 PM) *
agreed, DOT and HID are not related unless you run those pink HID ones or something i as cop would pull him over. HIDS come in stock from the factory so its not DOT related, its more of a standard and how US regulations test or ensure how glass/plastic is made on a car. and tires, wtvr.
QUOTE (Special_Edy @ Aug 31, 2012 - 9:34 AM) *
DOT is always if im wrong correct me but they are always outside in the lens somewhere showing DOT, SAE, or Stanley either way. i just think this cus i look at everyones lights and its always on the outside or visibile looking at it.
This post has been edited by trdproven: Aug 30, 2012 - 8:12 PM
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Aug 30, 2012 - 8:04 PM
Box
Joined Feb 23, '12
From Warrior, AL
Ditto on the HIR bulbs. They're considerably brighter than standard halogen, all you have to do to make them work with our housing is cut off a tab on the bulb's base.
Here's some specs for those interested.
9006 - 55 watts - 1000 lumens
9005 - 65 watts - 1700 lumens
9012 - 55 watts - 1870 lumens
9011 - 65 watts - 2350 lumens
D2R HID capsule - 35 watts - 2800 lumens
Definitely what I'll be switching to once my SilverStar bulbs burn out.
2001 Miata LS 5-speed
post Aug 30, 2012 - 8:13 PM
trdproven
Joined Aug 2, '05
From Guam
QUOTE (Box @ Aug 31, 2012 - 11:04 AM) *
for 9006 no need its plug n play, for the h1, you can just use the plastic ring that comes with the bulb holder or use the rubber grommet thats on the bulb wire to create the tightness.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Aug 30, 2012 - 8:37 PM
Box
Joined Feb 23, '12
From Warrior, AL
Here's a how to that I had found: http://shnu.us/HIR%20Trimming%20A.htm
post Aug 31, 2012 - 12:01 AM
trdproven
Joined Aug 2, '05
From Guam
problem with those halogen aftermarket replacement bulbs if you are not going HID, is that they burn out faster, and can melt the harness. when I didnt have HIDs yet, still those aftermarket bulbs, it burned my heavy duty harness, lucky it wasnt my stock harness. I see some brands now running it as stock wattage now. I really still think they dont run stock wattage though, maybe a bit higher like to 80watts range.
This post has been edited by trdproven: Aug 31, 2012 - 12:02 AM
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
Lo-Fi Version Time is now: August 31st, 2026 - 2:06 AM
