Sep 12, 2012 - 9:01 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 17, '08 From JB MDL, NJ Currently Offline Reputation: 30 (100%) |
So lets say that my 94 5s bit the dust. If i were to swap in a 96+ 5s what kinds of things do i need to keep an eye on? Parts that are non inter hangeable, etc....
This post has been edited by Spider77: Sep 23, 2012 - 7:36 PM |
Spider77 difference between 96+ and 94 5sfe Sep 12, 2012 - 9:01 PM
richee3 I know the harness and sensors (compliments of the... Sep 12, 2012 - 9:23 PM
Special_Edy Distributor, throttlebody, egr system and O2 senso... Sep 12, 2012 - 11:02 PM
bloodMoney You'll also need to swap out the front plate (... Sep 12, 2012 - 11:09 PM
Special_Edy QUOTE (bloodMoney @ Sep 13, 2012 - 12... Sep 12, 2012 - 11:21 PM
Spider77 Thanks for the replies. The one i was worried abo... Sep 13, 2012 - 5:34 AM
Special_Edy On the 94 there is no crankshaft position sensor. ... Sep 13, 2012 - 8:00 AM
Smaay QUOTE (Special_Edy @ Sep 13, 2012 - 6... Sep 13, 2012 - 9:16 AM
bloodMoney Right.
Reading PWNS me. I thought he was going f... Sep 13, 2012 - 1:15 PM
Spider77 I am replacing my shot 94 engine with a 96+ (to my... Sep 13, 2012 - 2:29 PM
Special_Edy pull the pan off and verify the rod bearing is sho... Sep 13, 2012 - 2:45 PM
Spider77 Or metal flecks glistening in your fresh oil....I ... Sep 13, 2012 - 7:11 PM
Spider77 OK....lets talk some minor differences in the year... Sep 18, 2012 - 6:45 PM
Special_Edy QUOTE (Spider77 @ Sep 18, 2012 - 7:4... Sep 18, 2012 - 6:55 PM
Spider77 Well....soldered a bit ago....pretty easy. Big wi... Sep 19, 2012 - 1:08 AM
Spider77 So....its running....sorta. real bad at idle and ... Sep 23, 2012 - 7:39 PM
Special_Edy QUOTE (Spider77 @ Sep 23, 2012 - 8:3... Sep 23, 2012 - 9:40 PM
Spider77 I checked the timing by lining up the notches and ... Sep 23, 2012 - 10:05 PM
Special_Edy Id check the vacuum, egr and pcv systems. Check th... Sep 23, 2012 - 11:47 PM
Smaay injectors cant get out of order but the connectors... Sep 24, 2012 - 9:19 AM
Spider77 Swaped em....pulled plug wires and still the same.... Sep 24, 2012 - 9:46 AM
Special_Edy QUOTE (Spider77 @ Sep 24, 2012 - 9:4... Sep 24, 2012 - 11:23 AM
Spider77 I have a spare around i think...... Sep 24, 2012 - 2:18 PM
Smaay check to see if you have spark, check to see if in... Sep 24, 2012 - 2:53 PM
Spider77 Im getting spark..... Sep 24, 2012 - 3:10 PM
Special_Edy If its starting and running its getting spark, che... Sep 24, 2012 - 4:04 PM
Spider77 Well...here is what i got....both injectors have r... Sep 24, 2012 - 6:19 PM
Akirad1 dang that sucks that your car is down Sep 24, 2012 - 9:24 PM
Special_Edy How about the missing VSS, is there a vacuum leak ... Sep 24, 2012 - 11:49 PM
Spider77 I still have a few places to check....mostly every... Sep 25, 2012 - 5:44 AM
Spider77 Code 22 anyone? Pulled coolant temp sensor code t... Sep 25, 2012 - 6:43 AM
Special_Edy Theres your misfire. Its the one with two wires on... Sep 25, 2012 - 8:05 AM
Spider77 Replaced and still the same.....damn.
So i got a g... Sep 25, 2012 - 6:52 PM
Special_Edy QUOTE (Spider77 @ Sep 25, 2012 - 6:5... Sep 25, 2012 - 9:07 PM
Spider77 Pulled injectors....two of them had some sort of b... Sep 28, 2012 - 5:27 PM
Spider77 Yeah....much better now.... Low end seems better ... Sep 28, 2012 - 8:14 PM
Spider77 So everything seemed fine....when i drove it same ... Sep 29, 2012 - 6:38 PM
Spider77 Word....swapped ecu's and now i have 3 active ... Sep 29, 2012 - 9:40 PM
Spider77 All injectors firing! Looks like ill be drivi... Sep 29, 2012 - 10:38 PM
Spider77 Drove around for a while....runs smooth now. So g... Sep 30, 2012 - 10:44 AM
Special_Edy QUOTE (Spider77 @ Sep 30, 2012 - 11... Sep 30, 2012 - 2:27 PM
Spider77 The only problem i have is a slight coolant leak, ... Sep 30, 2012 - 4:15 PM
Special_Edy Yeah, I always keep the underskirts off the car fo... Sep 30, 2012 - 5:00 PM![]() ![]() |
| Lo-Fi Version | Time is now: September 3rd, 2026 - 12:23 PM |
