Sep 18, 2012 - 11:38 PM
Enthusiast ![]() Joined Jun 2, '08 Currently Offline Reputation: 0 (0%) |
What is the difference between getting one that says it's for an automatic, and getting one that is for a standard transmission? They both look exactly the same. My car is standard, but they have cheaper ones out there for automatic, would it hurt if I just got the automatic one?
Sep 18, 2012 - 11:43 PM
What is the difference between getting one that says it's for an automatic, and getting one that is for a standard transmission? They both look exactly the same. My car is standard, but they have cheaper ones out there for automatic, would it hurt if I just got the automatic one? They are probably a different idle. MT idles higher, AT idles lower because the torque converter puts a load on the engine |
Sep 19, 2012 - 9:12 AM
What is the difference between getting one that says it's for an automatic, and getting one that is for a standard transmission? They both look exactly the same. My car is standard, but they have cheaper ones out there for automatic, would it hurt if I just got the automatic one? They are probably a different idle. MT idles higher, AT idles lower because the torque converter puts a load on the engine thats controlled by the ECU. the IAC should be the same -------------------- 2001 Celica GT-S Turbo
Sep 19, 2012 - 10:06 AM
[/quote] Well then I'm going to get one for an automatic, install it and then I'll let you know if it was ok. What's the worse that could happen, I send it back? |
Sep 19, 2012 - 10:28 AM
You should try taking apart the one you have and cleaning it with carb cleaner. 99% of the time they just need to be cleaned to function correctly again. Also, make sure you pick up a new gasket as the old one is not made to be reused.
| Lo-Fi Version | Time is now: September 15th, 2026 - 9:26 AM |
