> Clutch not being engaged
post Oct 6, 2012 - 7:39 PM
Malhar95
Joined Jul 5, '09
From Katy/houston
(My buddy's car) the car is acting like the clutch isn't engaged. We press it but nothing happens. Never had a manual car of my own so no idea
I think it's the master cylinder because of a old thread I read err where jim(or manny I think) was talking about
If the slave comes out when clutch pedal depressed and goes back in slowly it's the slave; if it doesn't move it's the master clutch cylinder.
But then I don't think so cuz the pedal wasn't getting stuck before ever. It was workin fine before. Suddenly we were havin problem putting it in third, then we pulled over and shut it off, then realized the car wouldn't detect the clutch pedal being pressedbasically.
I put it in gear, depressed the pedal and try to push it and the car doesn't move like its in gear(it's suppose to so that but not with the clutch pressed u know)
the pedal itself feels wierd like it would press in really easily without resistance and also when we let go its gonna push back out fast
http://i855.photobucket.com/albums/ab119/m...2A872E9DCBB.mp4
Is there any fluid I need to check?
This post has been edited by Malhar95: Oct 6, 2012 - 9:45 PM
- Malhar95   Clutch not being engaged   Oct 6, 2012 - 7:39 PM
- - BonzaiCelica   http://www.6gc.net/forums/index.php?showtopic=8723...   Oct 7, 2012 - 12:00 AM
- - Malhar95   Cables are fine, they're moving and in good co...   Oct 8, 2012 - 4:12 PM
- - Malhar95   Nvm the car doesn't even start as if I don...   Oct 8, 2012 - 4:19 PM
- - mkernz22   Yeah, that float is suppose to be in there   Oct 8, 2012 - 5:04 PM
- - rave2n   Your hydralic system is leaking somewhere, by the ...   Oct 8, 2012 - 5:07 PM
- - trdproven   if your master or slave is old, just replace both....   Oct 8, 2012 - 9:50 PM
- - Malhar95   Ordered slave from autozone for 18$ master wa...   Oct 8, 2012 - 10:21 PM
|- - Ted95   QUOTE (Malhar95 @ Oct 8, 2012 - 11:2...   Oct 9, 2012 - 7:20 AM
|- - BonzaiCelica   QUOTE (Ted95 @ Oct 9, 2012 - 7:20 AM...   Oct 9, 2012 - 12:08 PM
- - Smaay   call this guy, Dave Staba at ddperformanceresearch...   Oct 9, 2012 - 1:05 AM
- - Malhar95   Yea Toyota didn't have it in stock so parts st...   Oct 9, 2012 - 3:19 PM
- - Malhar95   Replaced the slave at first wasn't working and...   Oct 9, 2012 - 7:43 PM
- - Special_Edy   Yay, thank goodness it was a $20 slave cylind...   Oct 10, 2012 - 8:01 AM
- - Smaay   really? you didnt bleed it? glad you figured it ou...   Oct 10, 2012 - 11:25 AM
- - trdproven   I was supposed to do a write up on the slave repla...   Oct 10, 2012 - 7:57 PM
- - Malhar95   QUOTE (trdproven @ Oct 10, 2012 - 7...   Oct 10, 2012 - 9:32 PM
- - Smaay   QUOTE (Malhar95 @ Oct 10, 2012 - 7:3...   Oct 11, 2012 - 8:45 AM
- - Special_Edy   QUOTE (Smaay @ Oct 11, 2012 - 8:45 A...   Oct 11, 2012 - 12:29 PM
Lo-Fi Version Time is now: August 31st, 2026 - 9:31 AM
