> Locked up wheel
post Oct 10, 2012 - 9:37 PM
dudeofchaos
Joined Dec 9, '08
From Blainville
Just took the Gt-Four out for the first time yesterday... Well, that's what I planned to do.
Everything went well until I first clutched.. The rear left wheel is jammed and won't turn. It was fine when I stored it a while back. I can only see 2 options, either a jammed caliper or parking brake cable.
I'm not an expert but I can do things by myself. Could anybody help me with troubleshooting my problem? How can I find what's the problem and what do I need to do to fix it?
Thanks.
Replies (1 - 6)
post Oct 10, 2012 - 9:44 PM
mkernz22
Joined May 10, '10
From MA
did you have the parking brake on the whole time?
post Oct 11, 2012 - 3:05 PM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
sorry to hear of the troubles, hopefully its not the diff.
good luck
Mike W
269awhp / 273ft-lbs
post Oct 11, 2012 - 4:57 PM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
QUOTE (dudeofchaos @ Oct 10, 2012 - 9:37 PM) *
Thanks.
Remove the wheel, caliper and rotor from the car.
If you are still unable to turn the axle I would remove the halfshaft from the hub. With the halfshaft only connected to the differential you can check both the differential and hub for rotation seperately.
I would actually least suspect the differential. Just from my general knowledge the spider gear(even lsd) in the center means that neither axle could actually lock up, especially if the other axle is fine. I suspect the brake but it could somehow be the hub.
post Oct 11, 2012 - 7:53 PM
azian_advanced
Joined Apr 18, '05
From Calgary
i wouldn't be suprised if the parking brake cable seized up for that side. it's happened to 2 of my previous celicas...
post Oct 11, 2012 - 8:53 PM
dudeofchaos
Joined Dec 9, '08
From Blainville
Just set it free! It actually was the parking brake cable... Been sitting in the rain for 2 hours smashing a hammer at my hub hoping it'd release the pads inside... Seems like it worked! Still thanks to those who have replied smile.gif
I feel soooo damn stupid though. I almost forgot to put the wheel back on when I gave it some gas while on the jack.. I would've killed me if something happened. I'm never working on any car in the dark... Ever.
post Oct 11, 2012 - 11:21 PM
Special_Edy
Joined Oct 29, '11
It would burn up your LSD too.
One time I reached my arm in the window of my 64 chevy pickup to test start it after a repair and it was in gear. It chugged forward and plowed into the side of a Lincoln Towncar. A $10 chrome piece on the lincoln was the only damage biggrin.gif
Lo-Fi Version Time is now: September 3rd, 2026 - 12:22 AM
