Oct 18, 2012 - 1:58 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 4, '12 From US Currently Offline Reputation: 6 (100%) |
Here's my list: (They're for a 5S-FE)
Bearings: 1. ACL Race 3S-GTE Main Bearings 2. ACL Race 3S-GTE Rod Bearings (using 3S Stock Rods) 3. King Bearings 5S-FE thrust washer (not sure if 3S-GTE one will fit) Pistons/Rods: 1. CP 8.5:1 Pistons 87.5mm [+.020"] (trying to find a 9.0:1 set, if not I'll have to deck the head to bump up the compression) 2. Included Ring set and pins from CP 3. OEM 3S-GTE rods with ARP 22R/3S-GTE Rod bolts Gaskets/Seals/Head Stuff: 1. OEM 98+ MLS Headgasket 2. OEM 98+ Oil Pump (will most likely shim it 1.5mm) 3. Will reuse brand new water pump 4. Gen 2 3S-GTE ATS Thermostat (170 deg) 5. ARP Head Studs (www.raceeng.com seems to sell a set specific for the 5S. I was told the 3S set would fit but the two studs below the internal cam drive gears had to be ground down to clear the gears) What else am I missing? Which seals, etc.? -------------------- 1993 Celica GT Coupe - sold
1994 Celica GT Liftback |
Oct 18, 2012 - 9:14 AM
i would just get OEM main bearings. the crank doesnt see the loads the rods do so OEM will be fine. get the engine full rebuild kit. it will have all the seals for the head like valve stem and headgasket. its much cheaper to buy the kit.
Oct 18, 2012 - 10:54 AM
i would just get OEM main bearings. the crank doesnt see the loads the rods do so OEM will be fine. get the engine full rebuild kit. it will have all the seals for the head like valve stem and headgasket. its much cheaper to buy the kit. Any brand or site to get it from? I'm going to have to get 3S rod bearings anyways if I bought the kit. EDIT: And just about anything else that isn't a gasket or seal (like the headstuds) This post has been edited by Syaoran: Oct 18, 2012 - 10:55 AM -------------------- 1993 Celica GT Coupe - sold
Oct 18, 2012 - 12:19 PM
the 5S head is taller than the 3S so you need to find an off the shelf stud for another application.
i get some parts from here http://www.toyotapartseast.com/ -------------------- 2001 Celica GT-S Turbo
Oct 19, 2012 - 5:59 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 11, '08 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) |
I got JE pistons on advice that Wiseco and CP piston slap
-------------------- Mike W
Oct 19, 2012 - 6:04 AM
86.5mm is .020, 87.5 is too big.
Oct 19, 2012 - 10:33 AM
i have never had an issue with wiseco pistons, all my big HP engines have them. slap is caused by improper cylinder wall clearance.
Oct 19, 2012 - 1:10 PM
the 5S head is taller than the 3S so you need to find an off the shelf stud for another application. i get some parts from here http://www.toyotapartseast.com/ www.raceeng.com has a set for the 5s. The 3S ones fit just fine, it's just that two of them have to be modified or you have to find another stud that clears the gears. I'll buy the set from raceeng, so we'll see if they speak the truth. I got JE pistons on advice that Wiseco and CP piston slap 86.5mm is .020, 87.5 is too big. I quote the first post: Here's my list: (They're for a 5S-FE) 87.5 is .020" for the 5S-FE. i have never had an issue with wiseco pistons, all my big HP engines have them. slap is caused by improper cylinder wall clearance. Could be that JE uses different rings in a 3S-GTE application (i.e. better rings) vs CP and Wiseco. Not all engines are the same after all. I've read many things about piston slap being due to too much clearance to the cylinder wall, too, though. -------------------- 1993 Celica GT Coupe - sold
Oct 20, 2012 - 2:09 AM
rings have nothing to do with slap either. like i said its from too much clearance between the piston and the wall. thats it.for a NA application you want about .002 clearance. for a turbo build you want .003 to .0035 clearance.
Oct 20, 2012 - 8:20 AM
I remember reading somewhere that the 5S-FE stock comes with .0012" clearance and 3S-GTE comes with .0018" clearance.
| Lo-Fi Version | Time is now: August 27th, 2026 - 7:10 PM |
