> MR2 tranny
post Oct 19, 2012 - 1:31 AM
3Scelica
Joined Dec 8, '11
Does anyone know if I can use a mr2 lsd tranny on my 94 celica ???? It has the 3sgte motor.
post Oct 19, 2012 - 2:57 AM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Yes but it has to be modded to work
Something to do with the shifter links on it are backwards or something like that
Someone else can explain it better
It's probably in the stickys somewhere too
94 st hatch my daily driver
n
post Oct 19, 2012 - 2:02 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
e series transmission internals will not work on a s series transmission.
woops misread that.
e153 turbo mr2
s54 na celica's FWD
This post has been edited by BonzaiCelica: Oct 19, 2012 - 2:49 PM
post Oct 19, 2012 - 2:44 PM
JDM_Factory
Joined Mar 27, '08
From Fort Worth, TX
It will work and bolt up but the shifter linkage will need to be modded.
post Oct 19, 2012 - 9:09 PM
3Scelica
Joined Dec 8, '11
QUOTE (kurt95gt @ Oct 19, 2012 - 2:57 AM) *
what tranny do u have on that v6 swap?
post Oct 19, 2012 - 9:14 PM
3Scelica
Joined Dec 8, '11
QUOTE (JDM_Factory @ Oct 19, 2012 - 2:44 PM) *
so as far as I understood only problem is the shifter linkage. what about the axles? am I going to need mr2 axles as well for that?
post Oct 19, 2012 - 9:51 PM
richee3
Joined Jun 29, '08
From Denver
http://www.6gc.net/forums/index.php?showto...856&hl=e153
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Oct 20, 2012 - 2:03 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
ok to clear this up. the MR2 tranny bolts up just fine but the linkage is on the front side and the selector shaft is set up for that. its much better to get the 2002 Solara transmission. it has the linkage on the back and the newest synchros.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Oct 20, 2012 - 8:22 AM
kurt95gt
Joined Aug 23, '11
From kenton ohio
QUOTE (3Scelica @ Oct 19, 2012 - 10:09 PM) *
S54
n
post Oct 21, 2012 - 11:39 PM
3Scelica
Joined Dec 8, '11
QUOTE (Smaay @ Oct 20, 2012 - 3:03 AM) *
What about v6 camry tranny??? I heard those stronger than 5sfe tranny's.
post Oct 22, 2012 - 12:00 AM
kurt95gt
Joined Aug 23, '11
From kenton ohio
The camry v6 an solara trans smaay is talking about is the same one
An yes it is stronger than the stock gt s54 trans
Me like a lot of 3s swap guys stuck with the s54 to save money atm since it already works in my car
n
post Oct 22, 2012 - 12:40 AM
3Scelica
Joined Dec 8, '11
ok thanks for the info guys. last question if I get the v6 tranny do u guys know what clutch disc n plate use in? same as 5sfe tranny??
post Oct 22, 2012 - 1:07 AM
kurt95gt
Joined Aug 23, '11
From kenton ohio
No not the same as the 5s
It uses the same clutch as the 3sgte
n
post Oct 22, 2012 - 11:14 AM
3Scelica
Joined Dec 8, '11
ohhh reallyyy. thanks man. that's some useful info
post Oct 22, 2012 - 12:02 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
call southbend clutch. talk to Andy and have him send you the 1MZ clutch and flywheel. trust me this combination rocks!
post Oct 23, 2012 - 12:40 AM
3Scelica
Joined Dec 8, '11
sounds good man.
Lo-Fi Version Time is now: August 11th, 2026 - 10:00 AM
