Oct 21, 2012 - 8:54 PM
Enthusiast Joined Nov 17, '10 From Orlando Currently Offline Reputation: 0 (0%) |
I checked that the AC fan motor works by using couple of cables and connecting the fan directly from the battery. Then i checked the relays and there is only one that says FAN # 2 so i don't know if the relay is bad, checked relay for FAN # 3 by swapping the AC relay and the AC was working so i am guessing relay FAN # 3 was good. I was told to check the fuse but i can't find it. Can somebody direct to where i can find the AC FAN motor fuse and relay? Thanks for your help guys.
Oct 21, 2012 - 9:38 PM
you talking about the blower for the AC and heater? its behind the glove box
Oct 21, 2012 - 9:43 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Apr 11, '09 Currently Offline Reputation: 11 (100%) |
might need to replace the temp sensor at the bottom.
Oct 21, 2012 - 10:03 PM
might need to replace the temp sensor at the bottom. Well, the other fan is working and the car is not overheating but i use my ac most of the time because i live in florida. I just notice that becuase i set my ac control to full and the ac fan motor should run but it didn't that is why i checked it by connecting the fan motor to the battery. I just need to know why relay controls that fan motor to test it and also i need the fuse location to check if it is working or not. I checked the relay for fan # 1 and it works fine. Where i am in doubt is why fan relay # 2 and # 3. Do both control the AC fan motor? or only one, and which one is the right one. you talking about the blower for the AC and heater? its behind the glove box not, i am talking about the one that sits on the radiator. It is located on the left by looking the engine bay. |
| Lo-Fi Version | Time is now: August 31st, 2026 - 1:24 AM |
