> Will a 00-02 steering wheel fit on a 98?
post Oct 28, 2012 - 3:00 PM
MFWINTERS
Joined Oct 21, '12
From Phoenix, az
Hi,
I am looking to put a new steering wheel on my car, mine is worn out.
Will a 00-02 bolt straight on to a 98 GT. From the looks of it, it should? Any advice before I buy one?
Thanks.
post Oct 28, 2012 - 3:01 PM
richee3
Joined Jun 29, '08
From Denver
It'll bolt on but there is mild wiring work involved.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Oct 28, 2012 - 4:07 PM
MFWINTERS
Joined Oct 21, '12
From Phoenix, az
QUOTE (richee3 @ Oct 28, 2012 - 3:01 PM) *
Are there instructions on this? I only found 4 spoke to 3 spoke instructions, but didn't see instructions from a 3 spoke to 7 gen 3 spoke.
Thanks in advance.
post Oct 30, 2012 - 10:32 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
yes it bolts right on, just take the airbag off, then unbolt the wheel. wiggle it off, you dont need a puller. then put on the 7th gen wheel. you have to use the 6th gen cruise control and hold it in with screws. the airbag i de-pinned the connector and just spliced them together. there is an adapter out there but its hard to find.
here is a copy paste from my thread on Supraforums, the Supra is the same setup
ok i went out and took pics and realized that i never finished the Supra, i did the wiring splice on my 6th gen celica. They both are the same. when i bring the car home from the shop ill take the wheel off and get pics. but here is what i have so far. what i do know is I de-pinned the car side and cut the airbag side and then spliced them together permanently. I think what ill do on the Supra is make quick disconnects so its not permanent.
here is a link to the entire thread http://www.supraforums.com/forum/showthrea...highlight=wheel
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Oct 30, 2012 - 3:34 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
I bought my harness from here:
http://www.handsontools.com/OTC-Tools-0908...P-_p_49780.html
Had it in a few days. Completely plug and play.
**** Photobucket
post Oct 30, 2012 - 4:03 PM
Makabra
Joined Apr 16, '10
From Poland
I've done this. Before and after pics:
This post has been edited by Makabra: Oct 30, 2012 - 4:03 PM
post Nov 4, 2012 - 10:18 PM
trdproven
Joined Aug 2, '05
From Guam
the 6th gen 3 spoke and 7th gen 3 spoke are exactly the same thing, only differences are the air bag appearance and they are interchangeable 3 spoke air bags. The late model Celica like 98-99 the wiring became like the 7th gen, which means you either rewire or buy the adapter harness if you originally have a 94-97 celica, theres a pretty big thread on it.
This post has been edited by trdproven: Nov 4, 2012 - 10:18 PM
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
Lo-Fi Version Time is now: August 27th, 2026 - 8:38 PM
