> Help with aftermarket stereo install!
post Oct 29, 2012 - 2:11 PM
Xander_X
Joined Apr 22, '12
From Central NY
So I'm curious if I received/purchased the wrong harness adapter or if I'm just missing something. Every where I look for harness adapter, the one I have comes up though. (I have the 6 speaker, pre-amped stereo)
These are the ends of the harness adapter I already have wired up to my new deck
This was plugged into the factory preamp and comes from underneath it
This was plugged into the factory radio, the other end plugs directly into the factory preamp
This is the other end that was plugged into the factory preamp.
I know they make a harness adapter I can buy if I want to use the factory preamp ... but I don't.
99 Celica GT-S
91 Subaru Legacy Sport AWD Turbo
2010 Acura RDX Turbo w/ Technology Package
68 Impala SS Convertable
post Oct 29, 2012 - 3:37 PM
richee3
Joined Jun 29, '08
From Denver
Currently Online
I have the 6 speaker system as well. The harness I bought (Scosche) still runs through the factory amp. If I recall correctly, I did away with the harness that goes between the amp and factory head unit, and only used two plugs from the amp. I would have to look again to double check.
Edit: picture of the two plugs borrowed from Noberto's thread.
This post has been edited by richee3: Oct 29, 2012 - 3:44 PM
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Oct 29, 2012 - 4:42 PM
Xander_X
Joined Apr 22, '12
From Central NY
Thanks Rich, yeah I actually ended up finding a PDF made for 6gc's. Those 2 blue plugs are underneath the preamp and you gotta reach your hand underneath and pull them out. Ended up getting it.
99 Celica GT-S
post Oct 29, 2012 - 8:21 PM
richee3
Joined Jun 29, '08
From Denver
Currently Online
They're a pain to get out. I tried removing my factory amp several years back but that killed all power to my head unit. I have up on that endeavor. Are you still going for the 8 speaker system?
1998 Celica GT-
BEAMS Swapped.
post Oct 29, 2012 - 9:25 PM
Xander_X
Joined Apr 22, '12
From Central NY
^Not as of right now. If someone in the states, especially close by, were to sell a set of 8 speaker door trims ... I might take them up on it, if they were mint ... but I'm pretty happy with the sound I have now. The two plugs under the preamp aren't that hard to get, I'd try it again. I mean, they're not super easy but once I figured out which ones they were, it took me like 5 min to get them pulled out and reroute them to plug into the new harness.
I wanted to use the preamp in the new deck as it has more wattage output than the factory JBL preamp. It's loud! Any now I have my iPod plugged in and I can go through the albums and artists right on the touch screen without even using the iPod ... I like that convenience!
99 Celica GT-S
Lo-Fi Version Time is now: August 29th, 2026 - 7:37 PM
