Nov 8, 2012 - 2:24 AM
Enthusiast ![]() Joined Mar 22, '09 From Oahu, Hawaii Currently Offline Reputation: 0 (0%) |
Hey got a 95gt manual rad. fan problem where it wont turn on when its post to. When I turn on the a/c both fans turn but not when it gets hot. Swapped the fan relay and change the cooling fan switch but wont turn on. Grounded the connector on the cooling switch, fan turns on but when on the new one it doesn't. 808joey is helping out and said that it could be theromstat failure where its not open all the way to ground the switch to turn on the fans. I was wondering if you guys know anything else that might be the problem also no fuse for the fan motor.
-------------------- ![]() The New Kid on the Block |
Nov 8, 2012 - 7:19 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 10, '10 From MA Currently Offline Reputation: 37 (100%) |
I only thought they went on to help cool the car down. I don't think they ever went on with the AC
Nov 8, 2012 - 8:42 AM
If the fan temperature switch(its the sensor at the bottom passengerside of the radiator) is unplugged then the fans will run nonstop with the ignition on. If the switch is plugged in then the fans should only come on at temperature.
Open circuit = fans on Closed circuit = fans off |
Nov 9, 2012 - 3:58 AM
problem solve thermostat fail cracked thanks guys
| Lo-Fi Version | Time is now: August 28th, 2026 - 11:03 PM |
