Nov 12, 2012 - 6:59 PM
Enthusiast ![]() Joined Feb 20, '12 From Florida Currently Offline Reputation: 0 (0%) |
K so after I was done and started up the car the timing belt moved left (passenger side) from the center of both cogs. I freaked out thinking it was gonna fall off but held. It is off the sproket and cam just a little bit but holding on. Why is this happening? Even when I move it back a few times it keeps going to that spot. Also I don`t have the little metal piece in front of the timing belt cause the old one got damaged. kinda looks like my belt is vibrating a little, but the car runs fine no ruff idle nor misfiring or anything at all, runs like it always has. Maybe I`m overthinking it all? Advice would help thanks d=-)
xxgetbackupxx K So I changed the timing belt today and have a couple questions Nov 12, 2012 - 6:59 PM
RabidTRD Did you only replace the belt? Replace the tension... Nov 12, 2012 - 7:12 PM
xxgetbackupxx QUOTE (RabidTRD @ Nov 12, 2012 - 7:1... Nov 12, 2012 - 7:21 PM
mkernz22 Did you replace the tensioners or leave the old on... Nov 12, 2012 - 7:23 PM
xxgetbackupxx QUOTE (mkernz22 @ Nov 12, 2012 - 7:2... Nov 12, 2012 - 7:25 PM
Special_Edy Its a non-interference motor. Worst case is that t... Nov 12, 2012 - 7:27 PM
xxgetbackupxx QUOTE (Special_Edy @ Nov 12, 2012 - 7... Nov 12, 2012 - 7:39 PM
mkernz22 You have a lot to learn about cars I see. Whenever... Nov 12, 2012 - 7:43 PM
xxgetbackupxx QUOTE (mkernz22 @ Nov 12, 2012 - 7:4... Nov 12, 2012 - 7:54 PM
Syaoran The water pump isn't something you want to hav... Nov 12, 2012 - 9:09 PM
xxgetbackupxx QUOTE (Syaoran @ Nov 12, 2012 - 10:0... Nov 12, 2012 - 9:14 PM
Special_Edy QUOTE (xxgetbackupxx @ Nov 12, 2012 - 9... Nov 12, 2012 - 10:57 PM
soulshadow You need that timing belt metal retainer that sits... Nov 15, 2012 - 5:43 AM
xxgetbackupxx ****UPDATE***
Just would like everyone to know I... Nov 23, 2012 - 1:13 PM![]() ![]() |
| Lo-Fi Version | Time is now: September 15th, 2026 - 12:21 PM |
