> Motor mount issues
post Nov 13, 2012 - 2:06 PM
k-weaver
Joined Jun 5, '07
From Santa Maria
So I noticed my motor was sitting crooked. Its currently leaning downward on the passenger side. I found the rear mount (tranny) was busted (rubber cracked from one side to the other) so I went to the dealer and got a new one. It was a PITA to get in but I made it happen. After getting everything bolted back up I lowered my jack that was supporting the engine and to my surprise the engine was till crooked.
So the next day I unbolted the 3 bolts on the passenger side mount and after the last one came out the whole mount was loose. I found it was not even bolted to the engine. After getting it all the way out I found 2 of the 3 bolts that mount on the block are broken, inside the block. The third i have no idea where it went...
Has this happened to anyone before? If so how did you get them out? Access is very limited. I don't see it being possible without removing the motor. What do you guys think?
post Nov 13, 2012 - 2:12 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
the bolts for the bracket that the passenger side motor mount bolts to...are those what you are talking about?
エキサイティングカーレーシングチーム!
post Nov 13, 2012 - 2:20 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
^^^ thats what it sounds like, if that is the case, i dont really see an alternative but pulling the engine to have enough room in there to get them out. it also depends on where they are broken for how to get them out. take the engine mount off, and if you have threads sticking out, vice grips should get them out. if non, then you need to drill and use an easy-out to back them out.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Nov 13, 2012 - 3:09 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
Yeah, you will likely need to pull the motor to remove the broken bolts. At the very least you'll need to undo the front and rear mounts (supporting with a cherry picker) and leave the trans bolted in, then lift the motor with the cherry picker to swing up the passenger side of the motor and give you access.
I'd pull it out completely and give it a good cleaning though. You're basically going to be at that point - might as well go through with it and clean it all up.
**** Photobucket
post Nov 13, 2012 - 3:15 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
QUOTE (95CelicaST @ Nov 13, 2012 - 3:09 PM) *
エキサイティングカーレーシングチーム!
post Nov 13, 2012 - 3:38 PM
95CelicaST
Joined Feb 5, '05
giggity.
gif unrelated, but I like it so screw you if you don't.
**** Photobucket
post Nov 13, 2012 - 4:20 PM
k-weaver
Joined Jun 5, '07
From Santa Maria
QUOTE (Tigawoods @ Nov 13, 2012 - 8:12 PM) *
Exactly what i'm talking about.
QUOTE (Smaay @ Nov 13, 2012 - 8:20 PM) *
No threads sticking out. They are pretty much flush with the block. Easy-out is what I was thinking, just a matter of getting to them. Sounds like she's got to come out for this to happen.
post Nov 13, 2012 - 4:41 PM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
The broken bolts will either be a PITA to remove or they will be extremely easy. If the thread is relatively straight and clean then they will come out by hand.
Ive worked on a celica that had been in a front collision which had the same problem as yours. It was a 7a-fe and the bolts on the passenger-side motor mount had ripped out of the engine block(head?) and took chunks of the block with them
Lo-Fi Version Time is now: August 31st, 2026 - 2:00 PM
