> Not cranking & Code 12.
post Nov 14, 2012 - 10:19 PM
Takumi-FujiWaraS...
Joined May 29, '12
From NC
94 ST 5spd.
I'm having a issue car won't crank, so far i have check power/grounds, fuses, clutch safety switch all were good. I notice the fuel pump will only prime if you're trying to start the car (Key turned all the way), other than that i can roll start it and it pure like a kitten and pulled the codes and got 12 (Which i can't find codes anywhere), but car has no light on while it's running.
This is my dd and i need it up and going soon, until then i hate to but will roll start it when needed.
Cleaning and improving my new found yoter little by little.
Lo-Fi Version Time is now: May 17th, 2026 - 12:46 AM
