> Motor Mounts, 3S-GTE mounts for AT200
post Nov 18, 2012 - 4:11 PM
GlenW
Joined Nov 17, '12
From Oceanside, CA
Does anyone know where I can get custom motor mounts for cheap, I would like to find someone who can build them off the requirements so I don't have to tow my car and new motor to them.
Also I am swapping my 7A-FE for the 3S-GTE, other than the motor mounts will I need anything else to make it work besides the obvious shift linkage and pedal assembly. I know the basic stuff, but idk if there is anything else that won't match up
post Nov 18, 2012 - 4:19 PM
diegohiga
Joined May 4, '09
From coral springs florida US
im doing the same swap and from what i read you need gt A/C lines and throttle body cable
post Nov 18, 2012 - 5:53 PM
GlenW
Joined Nov 17, '12
From Oceanside, CA
Ok sweet, thanks man; I'll let you know if I encounter any additional requirents because I have to have the swap done by the end of thanksgiving
post Nov 19, 2012 - 2:36 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
you are going to need a GT transmission and the front, rear, and drivers motor mounts. the body will need to be modified to support them too. you could also get a Camry transmission and the ST205 engine mounts. all 4 of those mounts will work, but you will still need to modify the frame. there is a sticky covering all of this.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
Lo-Fi Version Time is now: September 4th, 2026 - 8:14 PM
