Dec 7, 2012 - 3:54 AM
Enthusiast ![]() ![]() Joined Sep 6, '12 From Holland Currently Offline Reputation: 1 (100%) |
I've heard that removing the resonator box on my 7AFE Celica ST would make the car breath more easily and give a little bit more sound.
Is that true? And how do I remove that box? Yesterday i removed my stock airbox and i've unbolted the three bolts holding the fusebox. But then I tried to remove the resonator box from underneath the fusebox but it seems like it cannot be done without removing the fuse box. I don't know however how to completely remove the fuse box. Unbolten is one, but removing is two. I'm a little bit worried to damage the cables going into the fusebox. Hope you can help. This post has been edited by onnaj: Dec 7, 2012 - 8:48 AM -------------------- |
Dec 7, 2012 - 1:12 PM
If you want to remove the boxes, remove the driver side fender.
Or remove the wheel liner and try to get it out that way. |
Dec 7, 2012 - 2:49 PM
What do you mean with wheel liner? And what's easier, removing the fender or the linder?
Isn't it possible to remove the fuse box? -------------------- |
Dec 9, 2012 - 7:52 AM
no one else?
Dec 12, 2012 - 12:37 AM
Enthusiast ![]() ![]() ![]() Joined Mar 24, '11 From 704 Currently Offline Reputation: 3 (100%) |
Wheel liner...you know the piece of plastic that's inside the fender well? If you don't..then I suggest you just leave it, its not like its gonna do anything bad. Mines still on there cause I haven't found a reason to take it off.
Dec 12, 2012 - 7:17 AM
Ah okay. I'm from Holland so i don't understand all words. But now i know for sure what it is!
Is it difficult to remove to liner? How many bolts or screws do i have to unbolt? Because past week i thought i had all bolts and screw out of it but it still didn't want to move a lot. Thanks again. -------------------- |
Dec 12, 2012 - 10:05 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 18, '09 From Orlando Currently Offline Reputation: 8 (100%) |
I'm from Holland, isn't that weird?
Hallo maat. When I removed the airbox, the top cover and filter came off first. In the bottom of the box are three 14mm (maybe 12) bolts. I also removed the fuse box, it was attached with a few 12mm bolts and a few screws, I think. The plastic pipe inside the fender came out with a bit of force. This post has been edited by SwissFerdi: Dec 12, 2012 - 10:05 AM -------------------- '97 ST \ Eibach \ KYB \ Kenwood \ Alpine \ Cusco \ OEM+ [sold 10/18]
'90 MX-5 Mariner Blue '93 MX-5 LE '07 Kawasaki Eliminator 125 silver '15 Optima Grey '04 206 GTi silve |
| Lo-Fi Version | Time is now: May 30th, 2026 - 1:18 PM |
