> Rubber surounds on Low beams.
post Dec 7, 2012 - 7:05 PM
broderp
Joined Nov 30, '12
From Ohio
Is there a good guide or picture that shows how those darn rubber rings go on the lights and what clips hold them?
I believe a see a right and left side so I think I have the right ring on each headlight, but the don't line up with the all the clips.
post Dec 7, 2012 - 8:14 PM
richee3
Joined Jun 29, '08
From Denver
I read on here a while back that rubber cement works wonders if you don't mind a permanent installation.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Dec 7, 2012 - 8:57 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
I used black silicone on mine
Takes some time but you can get them to come off later if need be
94 st hatch my daily driver
n
post Dec 7, 2012 - 9:53 PM
azian_advanced
Joined Apr 18, '05
From Calgary
fyi, only one clip (located at the top center of the headlamp) hooks the rubber surround to the headlamp. the rest of the clips simply hook the glass to the housing (even though it doesn't need it). the rubber surround is glued on the glass by the factory.
post Dec 7, 2012 - 10:45 PM
cheela
Joined Feb 2, '07
From Berlin, WI
they only fit on one way too. so maybe u just gotta rotate them around until they sit nicely.
post Dec 7, 2012 - 10:52 PM
broderp
Joined Nov 30, '12
From Ohio
QUOTE (azian_advanced @ Dec 7, 2012 - 10:53 PM) *
QUOTE (cheela @ Dec 7, 2012 - 11:45 PM) *
I suppose I will give it a try this weekend.......they sure like to slip off regardless of what position they are in. lol biggrin.gif Do you think if I buy new ones they will fit looser (the older rubber shrank or became less flexible??)
Lo-Fi Version Time is now: August 27th, 2026 - 7:09 AM
