> bearing at top of strut
post Dec 13, 2012 - 2:57 PM
pgiorgio
Joined Feb 24, '11
From mass
have a "creaking" noise coming from strut when I turn the wheels going slowly. Anyone else had a similar problem? Just had the struts replaced, but someone said it could be the bearing at top of strut, which was not replaced. The car has 170k miles on it.
Thanks,
Peter
post Dec 13, 2012 - 3:13 PM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
Strut mounts, you should always change them with the strut.
post Dec 13, 2012 - 7:54 PM
xrav22
Joined Jul 24, '08
From Canoga Park CA.
QUOTE (Special_Edy @ Dec 13, 2012 - 3:13 PM) *
Grease is the word.
post Dec 13, 2012 - 8:34 PM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
Blast it with some WD 40.
post Dec 13, 2012 - 10:08 PM
QUOTE (pgiorgio @ Dec 13, 2012 - 2:57 PM) *
Thanks,
Peter
Yup, I had this exact problem.
At first I thought it was an assembly issue, so I took the strut apart and put it back together. After that didn't work, I bought a new strut mount. When I went to replace it, the bearing completely fell apart! Needless to say that was the issue.
Its also possible that whoever did the strut didn't line up the upper spring holder with the arrow that should point out. If that is installed in the wrong direction, it can cause the spring to creek.
This post has been edited by lagos: Dec 13, 2012 - 10:09 PM
Lo-Fi Version Time is now: September 18th, 2026 - 9:56 PM
