> Car quit on the way to work, Car quit
post Dec 23, 2012 - 8:20 AM
Bigblock
Joined Feb 14, '09
From Mid West
Sputtered 1time.
Lights & radio work.
Starter just whines but doesn't engage.
Getting it towed to the shop but it'll be a festering days b4 kindasad.gif it gets checked. I know the owner of the shop so there's no problem with me checking things out.
Ideas???
Thanks
post Dec 23, 2012 - 8:32 AM
Fuzzyfo
Joined Nov 7, '12
From Puerto Rico
hmmm, when my wifes honda civic did the same thing your describing, the timing belt had snapped in half, better check it out, if you kept on trying to turn the car over it might have bent a vavle, good luck man
post Dec 23, 2012 - 9:06 AM
Bigblock
Joined Feb 14, '09
From Mid West
Thanks for the tip!
Crocodile tears if that's the case!!
post Dec 23, 2012 - 11:29 AM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
QUOTE (Fuzzyfo @ Dec 23, 2012 - 9:32 AM) *
All 6g celica engines are non interference motors so the valves cannot get bent on the pistons if the timing belt does indeed break.
It sounds like you said the engine doesnt turn over, do you think the motor may be seized or do you suspect the starter?
post Dec 23, 2012 - 12:39 PM
Bigblock
Joined Feb 14, '09
From Mid West
Starter doesn't engage, just spins.
Lights & radio were working.
Going 60, it sputtered once, quit.
Tried to restart, starter just spins without engaging the flywheel.
post Dec 23, 2012 - 12:44 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
Timing belt, pry back the cover and look or check the distributor to see if it's turning. If the crank pulley turns but the distributor does not, you know it's a timing belt. Only takes a friend and about 15 minutes to check that.
post Dec 23, 2012 - 2:24 PM
Bigblock
Joined Feb 14, '09
From Mid West
Belts will be checked & so will fuel pump & probably filter.
But why won't the srarter engage the flywheel, or does the motor rotate THAT easy??
Why would it just quit for no apparent reason other than timing belt if that's not the prob??
{ Scratches head like a chimpanzee }
post Dec 23, 2012 - 2:50 PM
bsamps4
Joined May 16, '10
From Raleigh
Ive got my money on ignition coil. Screw the shop. Diagnose it yourself.
post Dec 23, 2012 - 3:47 PM
Bitter
Joined Mar 11, '06
Yea, with no valves moving to create compression the engine spins very freely. WEEWEEWEEWEEWEE. You can probably turn the crank by hand without any tools if the belts were off.
http://www.youtube.com/watch?v=gJDOICwT8Vc
Hear how it cranks?
Hurry up and fix it before the spring meet!
This post has been edited by Bitter: Dec 23, 2012 - 4:04 PM
post Dec 23, 2012 - 4:06 PM
Bigblock
Joined Feb 14, '09
From Mid West
Thanks for the link!
Sounds VERY similar to that.
I'll be getting it soon.
post Dec 23, 2012 - 4:11 PM
Bigblock
Joined Feb 14, '09
From Mid West
QUOTE (bsamps4 @ Dec 23, 2012 - 3:50 PM) *
I don't have a volt//multi meter.
I'll put it on my list.
Meanwhile, my bud at the shop will give it the " Once over " anyway.
Thanks for the tips guys!!
post Dec 23, 2012 - 6:07 PM
mkernz22
Joined May 10, '10
From MA
Sounds like the coil. Mine just went on me recently. Car was running and then it sounded like a stalled it. Then it wouldn't restart. I had fuel, air, and compression so it had to be spark. In the end, it was the coil
post Dec 23, 2012 - 6:09 PM
Bitter
Joined Mar 11, '06
If it were just the ignition coil the engine would still crank with compression, not freely as he's describing.
post Dec 23, 2012 - 6:26 PM
bloodMoney
Joined Aug 4, '06
From Chicagoland
I agree with you Jordan.
Rob, I had a buddy that had a timing belt snap just getting off the highway in his 5s camry. I'd put my $$ with Bitter on this one. Not bad, it can be done in an hour or so. The sucky part is lining up the timing marks, but even that's not too bad....
~bloodMoney
post Dec 23, 2012 - 6:51 PM
Bitter
Joined Mar 11, '06
It's a great time to replace the oil pump seals as well, they leak like a crazy bitch once they let go and you have to take all your **** apart again to replace them. Same for the water pump...and while the cooling system is drained hoses and thermostat too!
And cam seal.
And distributor shaft seal, wrong end of the engine but it's probably leaking too. Cap and rotor while you're at it.
actually, just drop a 1MZ in there. **** that 5S.
post Dec 23, 2012 - 7:12 PM
bsamps4
Joined May 16, '10
From Raleigh
Can you send us a video? We are truley here to help, and by doing it yourself you save $ and learn a valuable lesson, and youhave more respect for the awesome car we all own.
post Jan 5, 2013 - 11:49 PM
Bigblock
Joined Feb 14, '09
From Mid West
Sorry I can't post a video.
Here's where Im at so far--
I believe its the timing belt--no compression when tried to restart, no fluid leaks at all.
Had the car 7 yrs & only things done besides tune up & oil changes--
Alternator,radiator, lower rad hose, thermostat, fenders, front bumper cover, passenger side hi-beam, sylvania bulbs. Its at the shop waiting its turn.
Did some searching & with the tips here, will be doing seals & water pump.
Sooo--do the timing belt & tensioners & gaskets come in kits or is everything separately purchased?
I have to go to the shop first thing Monday morning & discuss this with the mechanic.
He has never done anything like this before. I have no time nor all the tools to do it.
I leave for work at 4:15 AM & get home around 7PM.
I know you folks are eager to help-- Words cannot express my humble & heart-felt thanks!!
post Jan 6, 2013 - 12:04 AM
Neon90424
Joined Jan 19, '11
it all comes in a kit, you can search ebay with the keyword 5sfe and its accesories should pop up to give you a better idea on part#s or kits...
http://www.ebay.com/itm/Toyota-2-0-2-2L-3S...7f5&vxp=mtr
This post has been edited by Neon90424: Jan 6, 2013 - 12:06 AM
post Jan 6, 2013 - 6:26 AM
Bigblock
Joined Feb 14, '09
From Mid West
Thanks Neon! !
I'll be editing my info--
1994 hatchback, 1.8 7A 5 speed
post Jan 6, 2013 - 10:43 AM
Neon90424
Joined Jan 19, '11
http://www.ebay.com/itm/93-97-1-8-L-TOYOTA...4d1&vxp=mtr
there you go for 7afe
Lo-Fi Version Time is now: August 27th, 2026 - 7:06 AM
