> Dashboard Battery Light Is On, And other things...
post Dec 30, 2012 - 4:05 PM
twofoldjunk
Joined Apr 17, '10
From Tustin, CA
Hey 6gers,
So my dashboard battery light came on last night. Got my car home and am a little concerned. I've had a bunch of electrical issues over the last year or so and I'll outline what's happened so far:
Car cut out while driving about a year ago. Driving along, noticed my radio shut off, interior lights started dimming, then engine died. No electrical power to anything. Jumped it and limped home.
Replaced the alternator and battery. Drove it a bit, then it died again. Same thing, full electrical. I figured it was a loose connection. Had my mechanic silicone the wiring into place on the alternator. Ran fine for a while.
That was about a year ago.
Drove to work yesterday, noticed my dash light came on. I'm thinking it's just a loose connection. Made it back from work and am going to take a look right now.
Any ideas on what it could be? Bad alternator? Battery? (Both are about a year old, shouldn't be the issue?) Another issue?
It's an old 96 GT, 2.2.
Thanks,
Eddy
post Dec 30, 2012 - 5:27 PM
Neon90424
Joined Jan 19, '11
my gt4 use to do this alot.
check negative terminal from alt to ground. if its corroded, burnt etc.
check fuse box for loose fuses.. my main fuse would somehow become loose and i would lose all EFI spark etc...
post Dec 30, 2012 - 8:23 PM
diegohiga
Joined May 4, '09
From coral springs florida US
mine turned on when my alternator got bad.
post Dec 30, 2012 - 9:33 PM
Box
Joined Feb 23, '12
From Warrior, AL
Check all of your body grounds.
2001 Miata LS 5-speed
post Jan 11, 2013 - 1:20 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
check and clean grounds. replace battery terminals. check fuses. also check the big connector under the engine fuse box(inside it under efi fuse )
post Jan 11, 2013 - 10:10 AM
JasonTX
Joined Mar 1, '10
From TX
QUOTE (diegohiga @ Dec 30, 2012 - 9:23 PM) *
+1
but its not too hard to check w/ a multimeter
check voltage with car running and accessories off should be around 14.5 volts.
also the voltage of your battery is directly proportional to its state of charge
for example
12.6-12.72V= fully charged.
12.4V= 75% charged
12.25V=50% charged
12.00V= 25% charged
so if your alternator is outputing the correct voltage but if after you turn your car off you battery drops to say 12 volts you may have to start looking at your battery.
i dont know where you bought your battery but in the past i've had terrible luck with some cheaper brands. I've had one battery i got from walmart within a month it would not hold a charge then when i replaced it the 'new' one they gave me was bad. My own suspicion is they just put a jumpbox on those things when people bring them in and toss em back on the shelf without thought of measureing the current on a resistor
all that being said it may not be either of those things but at least you will be able to rule them out as likely causes
good luck and, please let us know how it goes
JN 3:16
post Jan 11, 2013 - 11:24 AM
rave2n
Joined May 29, '09
From Gainesville, FL
Mine won't shut off either.
New battery, new alt. Checked all the lines going to it.
Next is clean up all the grounds, but meh..save that for swap day.
post Jan 13, 2013 - 1:50 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
yea mine too!!
post Jan 16, 2013 - 6:46 AM
yagamius
Joined Feb 18, '09
From Costa Rica
in my case the light start blinking and stay for a few mins since I have the GT-Four bumper, my guess is because of the air flow is higher than normal bumper some cables don't like it so I need to check connections
1994 ST Celica --> no swap --> 7A rebuild
1974 Mustang --> Almost Restored
post Jan 24, 2013 - 7:27 AM
trdproven
Joined Aug 2, '05
From Guam
ive normally seen that with a bad alternator, in fact i just replaced my alternator just last year cus of that light. its either that or loose terminals, wiring, bad contact. but if it was working fine before and you didnt touch anything under there previously, ill bank on the alternator.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
Lo-Fi Version Time is now: August 27th, 2026 - 1:58 AM
