Jan 10, 2013 - 12:16 AM
Enthusiast ![]() Joined Mar 22, '10 From Philippines Currently Offline Reputation: 0 (0%) |
Hi,
Just wanted to know the flow rate of the stock fuel pump for a 3rd gen 3S-GE. My one got busted and was replaced with a Warlbro fuel pump which I think has a flow rate for 255 lph. I know this is more than what my engine needs and now my fuel economy is affected. I don't have the budget right now to replace it but knowing the difference in flow rate will help me understand better. Thanks, |
Jan 10, 2013 - 2:10 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 11, '08 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) |
ecu should adapt as long as o2 sensor and fuel reg are in order
changing to walbro affected my low rpm performance alot and chewed threw gas making no power, now i have power fc ecu i can see that my o2 sensor is stuck at 0.2v which is a constant lean situation which caused my standard ecu to add more fuel so if you do have any low rpm issues, this could be it -------------------- Mike W
Jan 10, 2013 - 3:09 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 24, '08 From Orange County, CA Currently Offline Reputation: 33 (100%) |
Hi, Just wanted to know the flow rate of the stock fuel pump for a 3rd gen 3S-GE. My one got busted and was replaced with a Warlbro fuel pump which I think has a flow rate for 255 lph. I know this is more than what my engine needs and now my fuel economy is affected. I don't have the budget right now to replace it but knowing the difference in flow rate will help me understand better. Thanks, by the way. the fuel pump for 7afe, 5sfe and 3sfe engines are all the same!!! -------------------- Group buy to replicate Narrow E series transaxle parts
http://www.6gc.net/forums/index.php?showto...p;#entry1107514 Items for Sale: http://www.6gc.net/forums/index.php?showto...p;#entry1107572 |
Jan 10, 2013 - 3:49 AM
u hate that sound!! haha i love it, wish mine was louder, i forgot, have you bypassed the resistor pack?
Jan 10, 2013 - 5:11 AM
@delusionz: i replaced my o2 sensor less than 2 years ago and the fuel reg has not been changed ever since. i don't have any air-fuel controller installed now so my settings just rely on the ecu. i'm not sure of the resistor pack if it was bypassed. from what i know, my installer changed the socket only to accommodate the warlbro pump.
@BonzaiCelica: the fuel pump that was previously installed is for 4afe/4age, i think. are the 3sfe and 3sge pump just the same too? thanks guys! |
Jan 10, 2013 - 6:35 AM
All NA 6th gen Celicas use a 90 lph fuel pump.
Jan 10, 2013 - 6:44 PM
Thanks for the info! So the Warltro pump I got is so much more than what is needed. That explains my high fuel consumption.
| Lo-Fi Version | Time is now: August 31st, 2026 - 2:06 AM |
