> Water in headlight, Water in headlight
post Jan 12, 2013 - 1:48 PM
Bigblock
Joined Feb 14, '09
From Mid West
So we had a lil bit of rain. My passenger side hi-beam is 1/2 full of water!!.. rolleyes.gif
Removing bumper is NOT going to happen!!
SO--
Can I drill a small hole for it to empty out then smear silicone over it to seal it, then peel it off if //when it happens again?.. kindasad.gif
I CAN use just the lows but it was great having hi's out on the country roads we drive to & from work making it way easier to see road verman & deer.. smile.gif
Yup I did a search & wish it were only condensation, but I am definitely NOT pulling the bumper cover!! I don't have the time to have it layed up again when I break stuff pulling it off!!!!
post Jan 12, 2013 - 3:48 PM
tto010
Joined Jul 6, '12
From NORWAY
QUOTE (Bigblock @ Jan 12, 2013 - 2:48 PM) *
SO--
fix it with a hammer.
post Jan 12, 2013 - 8:53 PM
Box
Joined Feb 23, '12
From Warrior, AL
Don't see why you couldn't just drill a hole through the bottom.
2001 Miata LS 5-speed
post Jan 12, 2013 - 9:02 PM
jordisonjr
Joined Jan 20, '09
From Winnipeg
It won't work.
Well, it will drain it but there will always still be that little bit of condensation in there, and it may mess up the shrouds within the headlight.
Did this when i had the usuall condensation buildup in my headlight and yea it worked, but since it was in there for so long all the rusty brown was still in there, so I ended up just buying a new headlight.
My Celica!
post Jan 12, 2013 - 9:11 PM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
QUOTE (jordisonjr @ Jan 12, 2013 - 9:02 PM) *
It won't work.
Ok so maybe drill the hole, drain it, and then run the headlight with a towel over it to evaporate the condensation. Then seal the hole(and the original leak)
post Jan 12, 2013 - 9:17 PM
Bigblock
Joined Feb 14, '09
From Mid West
Tomorow I'll drill the hole, heat it up, re-seal it. It is a new headlight!! BOOOO!!!... kindasad.gif
Thanks for the help // tips // confirmation!!
post Jan 14, 2013 - 1:59 PM
jordisonjr
Joined Jan 20, '09
From Winnipeg
How are you going to heat it up and re seal it without removing the head light?
My Celica!
post Jan 15, 2013 - 10:40 PM
trdproven
Joined Aug 2, '05
From Guam
bottom line to keep it from getting even water or moisture the whole thing has to be sealed right. Some people who get it cannot be theres even a tiny hole because thats all it needs to get moisture in. moisture and heat create those craps.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Jan 17, 2013 - 4:39 AM
aiq
Joined Dec 24, '12
I bought my 96 celica with water in the drive side high beam head light. The bulb was busted out and the bulb harness was not plugged back into the headlight assemble and that is how water had gotten in. I don't know how long the car sat like that because the water had turned yellow and rusty. My entire headlight is yellow from inside. I just heated up an old pointy screwdriver and drilled a hole in it from the bottom. All the water drained out and haven't had the water problem again aside from the headlight looking ugly.
post Jan 23, 2013 - 7:38 PM
trdproven
Joined Aug 2, '05
From Guam
take out the headlight, drain the water, take out the bulb, and put it in the sun. then seal it.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Jan 25, 2013 - 11:49 PM
Special_Edy
Joined Oct 29, '11
QUOTE (trdproven @ Jan 23, 2013 - 7:38 PM) *
Im assuming if you heat the headlamp up by turning it on, getting all the vapor out by removing the halogen bulb and blowing/circulating fresh air into it before the vapor condenses, you could avoid so hassle of drying it in the sun.
Though I highly recommend sealing the original leak, go ahead and pull the headlight if you need to, better now than later(when you have to buy a replacement)
This post has been edited by Special_Edy: Jan 25, 2013 - 11:49 PM
post Jan 28, 2013 - 5:07 AM
trdproven
Joined Aug 2, '05
From Guam
Well, you could also park the car in the sun. The way i did it before for mine, is to take out the bulb, and use a heat gun, that works too, ive tried it since our cars headlights are glass. takes some time.
This post has been edited by trdproven: Jan 28, 2013 - 5:08 AM
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
Lo-Fi Version Time is now: September 12th, 2026 - 12:07 AM
