Jan 19, 2013 - 7:15 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 31, '11 From Rochester, NY Currently Offline Reputation: 5 (100%) |
Whelp. Trying to decide if I want to go with D2 RS coilover system or BC BR's. I'm getting about $1,100 back in tax returns, so I can afford either.
The D2 RS's seem to have more settings, have bodies that are aluminum and are electroplated to resist rust. They're also purple and black. (Would match the lug and caliper theme I've got going) http://www.ebay.com/itm/D2-RACING-RS-COILO...16e&vxp=mtr Then there are the BC BR's. http://www.ebay.com/itm/BC-Racing-BR-Coilo...619&vxp=mtr Anyone have insight on either of these two setups? I feel like Timmy said he has them on his car, but I can't remember. Whoops. Could a moderator move this to Suspension and handling? >.> sorry. -------------------- 1994 Toyota Celica GT-S 5S-FE 190k Miles. Project car 1992 Toyota Celica GT 5S-FE 170k Miles. Daily driver/beater 1999 Toyota Camry LE 5S-FE 216K Miles. RIP You will be missed. ![]() *ASE Certified General Manager |
Jan 19, 2013 - 9:06 PM
BCs. Or Teins.....both are good choices
Jan 20, 2013 - 2:48 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 24, '08 From Orange County, CA Currently Offline Reputation: 33 (100%) |
BCs. Or Teins.....both are good choices Y not megans i havent heard but good things from them and cheaper allso -------------------- Group buy to replicate Narrow E series transaxle parts
http://www.6gc.net/forums/index.php?showto...p;#entry1107514 Items for Sale: http://www.6gc.net/forums/index.php?showto...p;#entry1107572 |
Jan 20, 2013 - 5:47 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '05 From Lincoln, Ar Currently Offline Reputation: 7 (100%) |
Put your money in a savings account!
Jan 20, 2013 - 8:07 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 22, '06 From Columbia, MD Currently Offline Reputation: 13 (100%) |
-------------------- ![]() 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
Jan 20, 2013 - 11:04 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 4, '12 From US Currently Offline Reputation: 6 (100%) |
Depends on what you want.
BCs (as they are sold) are much better suited for a street application because the rates on them are on the softer side (yet harder than stock and harder than most lowering springs) BC BR is as good as D2 RS in terms of build quality. -------------------- 1993 Celica GT Coupe - sold
1994 Celica GT Liftback |
Jan 20, 2013 - 3:37 PM
Basically I'm looking to lower the car right able a set of 16x8 0 offset rims with a 195/50/r16 tire and be able to preload so there won't be a bunch of rub when I hit bumps or take corners quick. I may be doing a bit of autocross as well.
Jan 20, 2013 - 4:22 PM
Basically I'm looking to lower the car right able a set of 16x8 0 offset rims with a 195/50/r16 tire and be able to preload so there won't be a bunch of rub when I hit bumps or take corners quick. I may be doing a bit of autocross as well. BCs let you preload the springs. The body is threaded so the preload setting is independent from the lowering setting. It's also rebound adjustable if I'm not mistaken, just like most other coilovers (Megans, D2) You can also contact them to see if you can order an "extreme drop package". -------------------- 1993 Celica GT Coupe - sold
Jan 21, 2013 - 2:57 AM
Basically I'm looking to lower the car right able a set of 16x8 0 offset rims with a 195/50/r16 tire and be able to preload so there won't be a bunch of rub when I hit bumps or take corners quick. I may be doing a bit of autocross as well. BCs let you preload the springs. The body is threaded so the preload setting is independent from the lowering setting. It's also rebound adjustable if I'm not mistaken, just like most other coilovers (Megans, D2) You can also contact them to see if you can order an "extreme drop package". not one single coilover on the market has rebound adjustment for our cars except hotbitz which is a custom made coilover. All coilovers available have compression adjustment. I check the pricier ksport coilovers which cost $1500 and they do not say they have rebound adjustment rebound adjustment is for coilovers that are used on the track. -------------------- Group buy to replicate Narrow E series transaxle parts
Jan 21, 2013 - 12:21 PM
Basically I'm looking to lower the car right able a set of 16x8 0 offset rims with a 195/50/r16 tire and be able to preload so there won't be a bunch of rub when I hit bumps or take corners quick. I may be doing a bit of autocross as well. BCs let you preload the springs. The body is threaded so the preload setting is independent from the lowering setting. It's also rebound adjustable if I'm not mistaken, just like most other coilovers (Megans, D2) You can also contact them to see if you can order an "extreme drop package". not one single coilover on the market has rebound adjustment for our cars except hotbitz which is a custom made coilover. All coilovers available have compression adjustment. I check the pricier ksport coilovers which cost $1500 and they do not say they have rebound adjustment rebound adjustment is for coilovers that are used on the track. Yes I was mistaken, I confused the names. -------------------- 1993 Celica GT Coupe - sold
Jan 23, 2013 - 4:31 PM
Enthusiast ![]() Joined Mar 19, '11 From Utah USA Currently Offline Reputation: 0 (0%) |
I would suggest putting on 205/50/16, mostly because there are a lot more tires made in that size than the 195/50/16. but that's just me.
-------------------- 90' Toyota Celica GT (sold)
99' Toyota Celica GT |
Jan 23, 2013 - 7:40 PM
BCs or Megans. ONLY Get teins if its the higher end models, the Tein basics are junk.
Jan 23, 2013 - 9:03 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Oct 18, '06 From cincinnati Currently Offline Reputation: 10 (100%) |
I have the D2's and they are awesome!
-------------------- proud =3sgte SWAPPED= '95 Celica ST owner [calling it the GT2 or half-trac]
309,000 miles n' .... |
Jan 24, 2013 - 1:32 AM
The two tires I'm looking at are General G-Max and the Nankang RSII's (I think that's the name). They come in a 195/50/16. I want stretch, or I'd do 205
Also, the description on the BC BR's is that they're rebound adjustable. This post has been edited by RabidTRD: Jan 24, 2013 - 1:42 AM -------------------- 1994 Toyota Celica GT-S 5S-FE 190k Miles. Project car 1992 Toyota Celica GT 5S-FE 170k Miles. Daily driver/beater 1999 Toyota Camry LE 5S-FE 216K Miles. RIP You will be missed. ![]() *ASE Certified General Manager |
Jan 24, 2013 - 1:33 AM
BCs or Megans. ONLY Get teins if its the higher end models, the Tein basics are junk. i wonder the quality of the euro/jap spec tein superstreet coilovers. softer spring rates and pillow ball mounts :? -------------------- Group buy to replicate Narrow E series transaxle parts
Jan 24, 2013 - 6:58 AM
the super streets are not bad, but they normally come with no top mount (seen it a few times people using stock mounts unless its an option to pay more to get it) and adjustability as far as I know is not the 3 ring type like newer type models. its still like a single ring nut adjustment, kinda like a generic coil sleeve setup. SS dont have that much adjustment either, no camber, no preload, etc. their damper setting just to ride normal is the stiffest setting and its still not stiff enough. on megans or bcs there is more adjustment left which is nice. I had tein basics on my other celi and i ordered BC coilovers that same day i installed the teins - it was damn bouncy and it couldnt even drop low enough, i was only just over 1 in adjustment still lots of finger gap and realized that was considered by tein manual over the limit, wow, why get them if they barely even drop lower than springs. IDK, many of my friends have teins because of the name but they agree that its not that great. tein are generally built for japan type streets where you go slow and roads may be a bit better, so with softer spring rates like you mentioned to the rest of the world is super bouncy.
This post has been edited by trdproven: Jan 24, 2013 - 7:00 AM -------------------- 94 Celica GT
Jan 24, 2013 - 10:12 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 5, '05 From pineapple under the sea Currently Offline Reputation: 9 (100%) |
Its too bad KW doesn't have anything for the 6th gen. Going from cheap coilovers like K-sport, D2, Megan, etc. to something like a KW V3 is night and day.
Never again will I purchase $1000 coilovers. Ever. -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
Jan 24, 2013 - 1:37 PM
^ why what coilovers did you have?
Jan 24, 2013 - 6:24 PM
My Celica had Ground Control sleeves, but I have taken a ride in a 6th gen with Megans and hated it. It didn't make the car handle any better (I would say it was worse). Stiff does not equal better.
Most of the brands just the same junk, just rebranded. MR2 has DGR - another ~$1000 brand that I wouldn't recommend. FR-S has KW V3s - FAR superior, but cost a bit more. I highly suggest spending the extra money. -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
Jan 24, 2013 - 6:28 PM
My Celica had Ground Control sleeves, but I have taken a ride in a 6th gen with Megans and hated it. It didn't make the car handle any better (I would say it was worse). Stiff does not equal better. Most of the brands just the same junk, just rebranded. MR2 has DGR - another ~$1000 brand that I wouldn't recommend. FR-S has KW V3s - FAR superior, but cost a bit more. I highly suggest spending the extra money. Really? actually the people who rode on my coilovers freak out how i dont have to slow down and they said it feels better than stock and some say it doesnt even feel dropped. My wife drives the other one and i dropped it when she was gone, when she came back and just drove it, I asked her about the ride, she said I didnt notice anything what do you mean?, she didnt even realize it was lowered. I know a lot of people that do not know how to tune these coilover adjustment to their roads, in fact im the only one that knows how out of my friends, and i usually do this by driving in every single possible good and crap road to find the best compensating adjustment, takes sometimes days to a couple weeks to complete to get it right to the point where i never touch it anymore. This post has been edited by trdproven: Jan 24, 2013 - 6:30 PM -------------------- 94 Celica GT
| Lo-Fi Version | Time is now: September 1st, 2026 - 7:56 AM |
