Jan 19, 2013 - 8:08 PM
Enthusiast ![]() Joined Jul 22, '12 From SouthEast Currently Offline Reputation: 0 (0%) |
Hi,
I am poor and had to replace all four tires. Found a used set that was a little different from the original tires. The ones I bought are a little taller and a little smaller width wise. The ride actually is much smoother but the steering feels a little stiffer, a little harder to turn the wheel. Of course that may be because the old tires were apparently way over inflated. Anyway, they seem fine. I understand that when the speedo says 60 mph I may actually be going 61, but other than that, anyone know a problem with this size? Again, the ride seems much smoother but that again may be because of the apparent over inflation problem with the last set. |
Jan 20, 2013 - 12:17 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '05 From Calgary Currently Offline Reputation: 20 (100%) |
they're smoother because they have a higher sidewall.
205mm x 55% = 112.75mm 195mm x 60% = 117.00mm also, you shouldn't have a problem with that tire size. you'll probably even get better gas mileage with those. -------------------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- |
Jan 20, 2013 - 4:52 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 31, '11 From Rochester, NY Currently Offline Reputation: 5 (100%) |
I run hose dimensions as a winter tire
-------------------- 1994 Toyota Celica GT-S 5S-FE 190k Miles. Project car 1992 Toyota Celica GT 5S-FE 170k Miles. Daily driver/beater 1999 Toyota Camry LE 5S-FE 216K Miles. RIP You will be missed. ![]() *ASE Certified General Manager |
Jan 23, 2013 - 4:23 PM
Enthusiast ![]() Joined Mar 19, '11 From Utah USA Currently Offline Reputation: 0 (0%) |
That size should work great. Stock Tire - 205/55R15 Search Tires Tire 1 - 195/60R15
Section Width: 8.07 in 205 mm Section Width: 7.67 in 195 mm Rim Diameter: 15 in 381 mm Rim Diameter: 15 in 381 mm Rim Width Range: 5.5 - 7.5 in Rim Width Range: 4.5 - 7.5 in Overall Diameter: 23.87 in 606.29 mm Overall Diameter: 24.21 in 614.93 mm Sidewall Height: 4.43 in 112.52 mm Sidewall Height: 4.60 in 116.84 mm Radius: 11.93 in 303.02 mm Radius: 12.10 in 307.34 mm Circumference: 74.98 in 1904.4 mm Circumference: 76.05 in 1931.6 mm Revs per Mile: 871.3 Revs per Mile: 859.1 Actual Speed: 60 mph 100 km/h Speedometer1: 59.1 mph 98.5 km/h Speedometer Difference: - Speedometer Difference: 1.420% too slow Diameter Difference: - Diameter Difference: 1.41% -------------------- 90' Toyota Celica GT (sold)
99' Toyota Celica GT |
Jan 23, 2013 - 7:39 PM
i run those on my stock only cus they're cheaper.
| Lo-Fi Version | Time is now: August 31st, 2026 - 10:02 PM |
