> AMPLIFIER ADVICE, is this good and what is best??
post Jan 20, 2004 - 1:02 AM
GT_silver
Joined Feb 25, '03
From Sebastian, FL.
SO im in the sound stage of my car transformation and am throwing three 10 audiobahns in the back. 300 watts rms i was looking at this 1000w kenwood amp. I think the number is 8010D just wanted to know if ne of you ppl can vouch for it?? Also what else may be good for this type of hookup??
much gras in advance,
silver
Replies (1 - 5)
post Jan 20, 2004 - 1:06 AM
GT_silver
Joined Feb 25, '03
From Sebastian, FL.
ok so i just looked it up and its an 8101D and im getting it at about a 100 dolla discount. neway thanx for your input again
post Jan 20, 2004 - 9:10 AM
AudioFreak
Joined Dec 19, '02
From West of Atlanta
Kenwood amps are ok. Your audiobahns will need plenty of power. Personally I like MTX amps but I am a little biased after working at one of their dealers. Many people here suggest US Amps. I have heard good things about them but have never used them.
Just remember that a quality amp will cost $$$. All quality amps will be rated in rms or continuous power because it is a more accurate measure of an amps performance.
With three subs you'll have a little less than a 2 ohm load on your amp. Make sure the amp you choose is capable of this.
The 8101D is rated at 400w x1 at 2ohms. 1000 max or peak power. That means you'll get about 133 watts to each of your subs.
One last thing a true 1000 watts rms amp will draw a lot of current. Some where in the area of 100 amps. Our stock alternator is 70 amps. You will be putting one hell of a load on your charging system. (Just something to think about)
post Jan 23, 2004 - 1:59 AM
FAQdaWorld
Joined May 24, '03
From Milton, Delaware
MTX ARE good quality amps, ur not biased...
-Ryan
AIM : FAQdaWorld
post Jan 23, 2004 - 8:40 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
yeah the kenwood is nice, but def wont have enough rms power to handle three 300 rms subs, , imo i would go witha rockford, the 700s should be putting out around 800 rms @ 2 ohms
mine is clocked at 899 @2 ohms, for two rockford he2's 400 rms each
post Jan 24, 2004 - 1:03 AM
celimanST
Joined Nov 15, '03
From mississippi
ARC amps are the best! Really good quality. If you are on a budget MTX or interfire are two good amps for the money. I personally have the interfire amp and has never given me any problems, NONE.
William
Lo-Fi Version Time is now: September 14th, 2026 - 8:35 PM
