> gen3 3sgte vsv wiring
post Jan 31, 2013 - 4:18 PM
match220
Joined May 13, '06
From Kaimuki, HI
I know it's only two wires, but I don't have the original plug. I'm guessing that since it's just a solenoid then I can wire it either way, but I want to be sure. Does anyone know? Or can you attach a picture of your gen3 vsv wire colors on the plug? Thanks!
-Jay
95 GT conv. project car: Manual, Gen III 3sgte, JN pisons, Eagle rods, overbore, crank knife-edged, crank scraper, ARP head/main/flywheel, Autronic EMS, Haltech Dual Wideband O2 controller, Audi 1.8T individual coils, FMIC and SSQV BOV, 3" downpipe, 3" ultra-high-flow cat, 2.5" Borla muffler, +other
01 S2000: FMIC, Haltech EMS, Haltech wideband, 570cc inj, forged pistons/rods, sleeved block, 5 angle valve job, ported and polished
02 R6, all stock, except for braided stainless brake lines, frame sliders, and adjustable brake/clutch leve
post Jan 31, 2013 - 5:35 PM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
sorry pal, both wires are black with a red stripe and i dont have a multimeter with me. trololo
if it helps, the AC idleup plug is similar, if you hold it up with the locking tag up top, and the wires towards you the negative is on the left
try it both ways anyhow, see what works best
This post has been edited by delusionz: Jan 31, 2013 - 5:36 PM
Mike W
269awhp / 273ft-lbs
post Jan 31, 2013 - 5:57 PM
match220
Joined May 13, '06
From Kaimuki, HI
QUOTE (delusionz @ Jan 31, 2013 - 12:35 PM) *
thanks man. It's good to know that both of the wires are the same color. I know the ecu will short it to ground to turn it on, that's all I need to configure in my Autronic. It does look like it's a regular solenoid then if both wires are the same. They wouldn't make them both the same color if it's crucial that they be connected only one way.
The plug that I found (I think from a 5sfe) is from one of the vsv a/c idle up I think. It has a red/yellow wire and I forget the other wires color, but the red/yellow comes from the computer. The plug style is the exact same as the turbo vsv, so I want to use it and wire it in directly. Since both wires are black/red then maybe I'll chance it and see what happens. Or at least connect it each way and blow through it smile.gif
-Jay
post Jan 31, 2013 - 7:34 PM
delusionz
Joined Feb 11, '08
im actually interested to know if you can cut that plug off and wire in a 3port solenoid, i have the power FC ecu with 4 boost presets, unfortunately they only offer duty cycle, no gain
you will probably have a full fledged EBC in your autronic though
Mike W
269awhp / 273ft-lbs
post Jan 31, 2013 - 8:01 PM
match220
Joined May 13, '06
From Kaimuki, HI
QUOTE (delusionz @ Jan 31, 2013 - 2:34 PM) *
that's why I love the autronic..tons of neat features. I believe it does have a full EBC, I'll play around with that after the car is running and I have a good running map.
-Jay
post Feb 2, 2013 - 5:36 PM
match220
Joined May 13, '06
From Kaimuki, HI
it works fine both ways. 12v from battery, configured Autronic to short to ground. (and I wired a little LED onto the plug so I can see when it's on smile.gif )
-Jay
Lo-Fi Version Time is now: August 26th, 2026 - 7:38 AM
