Feb 5, 2013 - 1:34 PM
Enthusiast ![]() Joined Feb 5, '13 Currently Offline Reputation: 0 (0%) |
Hey everyone, I own a 94 Celica ST with the 7afe motor in it. I have 4k to throw into this car and want to redo to handle boost and hopefully generate some great hp with it. I have basically every piece of parts i need gathered but still need a little help on some topics. Here are the parts I have so far:
1) 4age forged pistons still keeping it at 9.0:1. 2) forged 7afe H beam rods 3) stock crank 4) Bored out cyclinders 5) t2 turbo kit 6) aem piggy back 7) boost gauge 8) colder spark plugs 9) 440cc injectors 10) 12.1:1 FMU 11) 255 fuel pump 12) wide band o2 sensor and gauge The thing ive been thinking about is, Do i need a different crank to handle the extra stress that i will be putting on this motor? some people online are saying its forged and the other half are saying its not forged. So does anyone know for sure which one it is?? I have no idea how much power i will be able to generate with this setup but it will be towed to the dyno shop as soon as the build is complete. Of course i wanna make sure everything is able to handle the boost ima be shoving into it. I have no idea on how much boost i will be able to run, hopefully 15psi or more depending on what the dyno people do. I have never turbod a 7afe before only did hyundai tiburons before this, but i did do tons of research on the 7afe, but still have some remaining questions. Also does anyone know what else will be needed to do to sqeeze the most power out of this motor as i can? without doing a swap of any kind. Also it will be nice to know if anyone has a similar build and see what kind of numbers they are generating. Thanks. This post has been edited by rapid36: Feb 5, 2013 - 1:57 PM |
rapid36 Building the 7afe to handle boost Feb 5, 2013 - 1:34 PM
mkernz22 Everything you will ever need to know
http://www.... Feb 5, 2013 - 2:20 PM
rapid36 QUOTE (mkernz22 @ Feb 5, 2013 - 2:20... Feb 5, 2013 - 3:21 PM
Smaay actually the 1MZ weighs about the same as a 7A-FE.... Feb 5, 2013 - 3:25 PM
rapid36 QUOTE (Smaay @ Feb 5, 2013 - 3:25 PM... Feb 5, 2013 - 3:31 PM
mkernz22 Click the link to the thread I posted, you might e... Feb 5, 2013 - 5:34 PM
Smaay the 7A is cast Iron. the MZ is Aluminum. I can eas... Feb 5, 2013 - 6:37 PM
rapid36 oh ok, well i already bought most of the parts tha... Feb 6, 2013 - 11:16 AM
Smaay tell me more about this transmission you have, wha... Feb 6, 2013 - 12:09 PM
rapid36 QUOTE (Smaay @ Feb 6, 2013 - 12:09 P... Feb 6, 2013 - 1:59 PM
mkernz22 Just because the clutch can handle up to 400hp doe... Feb 6, 2013 - 3:06 PM
rapid36 QUOTE (mkernz22 @ Feb 6, 2013 - 3:06... Feb 6, 2013 - 4:09 PM
mkernz22 I didn't know what your power goals were, but ... Feb 6, 2013 - 4:57 PM
rapid36 QUOTE (mkernz22 @ Feb 6, 2013 - 4:57... Feb 6, 2013 - 5:50 PM
Syaoran Transmissions don't handle HP, and cars don... Feb 7, 2013 - 4:11 PM
Smaay QUOTE (Syaoran @ Feb 7, 2013 - 1:11 ... Feb 7, 2013 - 4:23 PM
rapid36 QUOTE (Syaoran @ Feb 7, 2013 - 4:11 ... Feb 7, 2013 - 4:27 PM
Syaoran HP is a measure of torque multiplied by the RPM wh... Feb 7, 2013 - 5:12 PM
rapid36 QUOTE (Syaoran @ Feb 7, 2013 - 5:12 ... Feb 7, 2013 - 5:22 PM
Smaay QUOTE (Syaoran @ Feb 7, 2013 - 2:12 ... Feb 7, 2013 - 6:16 PM
rapid36 So does anyone know if i will need a forged crank ... Feb 8, 2013 - 11:04 AM
Smaay stock crank is fine. i dont think the 4A pistons a... Feb 9, 2013 - 4:28 PM
rapid36 QUOTE (Smaay @ Feb 9, 2013 - 4:28 PM... Feb 11, 2013 - 1:17 PM
Smaay i still no point in sinking all that money into a ... Feb 11, 2013 - 1:26 PM
rapid36 QUOTE (Smaay @ Feb 11, 2013 - 2:26 P... Feb 11, 2013 - 5:56 PM
mgnt232 you can buy a 3s clip for like 3-4k and push quite... Feb 11, 2013 - 6:35 PM
Smaay QUOTE (rapid36 @ Feb 11, 2013 - 2:56... Feb 11, 2013 - 9:56 PM
celica74 If your looking to get 300hp out of a 7a your look... Feb 11, 2013 - 9:56 PM
rapid36 QUOTE (celica74 @ Feb 11, 2013 - 10... Feb 12, 2013 - 11:26 AM
mgnt232 I think everyone gets it what your going for. And ... Feb 12, 2013 - 1:19 PM
rapid36 QUOTE (mgnt232 @ Feb 12, 2013 - 1:19... Feb 12, 2013 - 4:53 PM
mgnt232 >click here<
That link is to pressure2 (a mo... Feb 12, 2013 - 7:07 PM
rapid36 QUOTE (mgnt232 @ Feb 12, 2013 - 8:07... Feb 13, 2013 - 11:20 AM![]() ![]() |
| Lo-Fi Version | Time is now: August 26th, 2026 - 3:15 PM |
