Feb 14, 2013 - 1:29 AM
Enthusiast ![]() ![]() Joined Apr 24, '04 From S. Cali Currently Offline Reputation: 0 (0%) |
I'm rebuilding my 5s and want to use the metal headgasket instead of the crap one in my gasket set, does anyone have the part number? While i'm here, there won't be any issues using it on an older 5s, right? Mine is a 95.
Thanks |
Feb 14, 2013 - 2:02 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 15, '08 From Royal Oak, MI Currently Offline Reputation: 7 (100%) |
If you're ordering online, just pick the 98+. AFAIK they only have MLS gasket. No more composite.
-------------------- God made man....
Everything else... Made in China ![]() |
Feb 14, 2013 - 2:04 AM
There are no issues with using it with an older motor?
Feb 14, 2013 - 8:38 AM
The Fel-Pro head gasket for the 5sfe is metal. Supposedly all the 5sfe head gasket replacements were updated once toyota realized their mistake. I put the felpro gasket set on my 94 GT no problem and I've got 15k miles on them.
Feb 14, 2013 - 9:07 AM
I ordered one for a 98 camry but i do believe that the metal one supersedes all the old ones
Feb 15, 2013 - 12:12 AM
Enthusiast ![]() ![]() Joined Jun 5, '07 From Santa Maria Currently Offline Reputation: 1 (100%) |
Make sure you have a good gasket scraper, those old ones are a PITA to get off.
Feb 15, 2013 - 10:20 AM
Actually you need to take the cylinder head to a machine shop and have them check it. Most likely they will need to resurface it, it set me back $35 but they even dipped it for that price. Not a speck of dirt on it when I got it back.
The block is iron and much less likely to need resurfacing. And make sure to check your valve shim clearances before and after starting the motor for the first time after the rebuild. Some kids mixed up all my lifter buckets/shims, it cost me a burnt valve because I didn't double check. |
Feb 15, 2013 - 11:08 AM
Actually you need to take the cylinder head to a machine shop and have them check it. Most likely they will need to resurface it, it set me back $35 but they even dipped it for that price. Not a speck of dirt on it when I got it back. you dont have to do this. as long as you havent overheated the engine it will be fine. i have a good straight edge and every head i check is within .001 if that. i have a good scraper to get the old gasket residue off and then i hit it with a scotch brite pad -------------------- 2001 Celica GT-S Turbo
Feb 15, 2013 - 1:32 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Sep 27, '10 From pittsburgh Currently Offline Reputation: 4 (100%) |
Actually you need to take the cylinder head to a machine shop and have them check it. Most likely they will need to resurface it, it set me back $35 but they even dipped it for that price. Not a speck of dirt on it when I got it back. you dont have to do this. as long as you havent overheated the engine it will be fine. i have a good straight edge and every head i check is within .001 if that. i have a good scraper to get the old gasket residue off and then i hit it with a scotch brite pad That's what I thought until I put the head back on my 5sfe. Definitely had coolant getting into the cylinders. Mine was .0006 above the given tolerance. Once it was resurfaced I had no issues. But you're right if you check it and its within tolerance, no reason to have it resurfaced. -------------------- -93 Rx7, Turbo 6.1L v8, 725rwhp/760rwtq
-95 Celica GT Rally Car - 3sge/AWD -10 F150 Always buying stock wheels... PM me if interested in selling. |
Feb 15, 2013 - 2:57 PM
The oem composite gasket left indentations on my 94 5SFE head. Like pockmarks everywhere.
Also if you think about it a motor with a blown head gasket is much more likely to have overheated and warped, not to mention nearly 20 years of heat cycles. |
| Lo-Fi Version | Time is now: May 24th, 2026 - 10:00 AM |
