> Metal Shavings in the oil pan
post Feb 21, 2013 - 9:26 PM
ClevelandGaint
Joined Feb 12, '13
From Cleveland
Yesterday i was changing out the oil pan gasket to stop the oil leak and while cleaning it out, i discovered metal shavings in the oil pan. What needs to be replaced asap? Is it shavings from a bearing or a rod? What are the parts i should replace to make it clean again? All the help will be great
post Feb 21, 2013 - 9:36 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
a large amount of shavings?
エキサイティングカーレーシングチーム!
post Feb 21, 2013 - 9:45 PM
ClevelandGaint
Joined Feb 12, '13
From Cleveland
Not alot but enough to look like theres glitter in but its metal. I would do a rebuild but i dont know what parts i need to do it
QUOTE (Tigawoods @ Feb 21, 2013 - 9:36 PM) *
post Feb 21, 2013 - 10:48 PM
Box
Joined Feb 23, '12
From Warrior, AL
Meh, I wouldn't worry about it. Once it starts making noises, then be concerned. Rebuilding now would be a waste of money and time. Most cars have a magnet in the oil pan that'll keep all the shavings from going around the engine. If that is the case for our cars then those metal shavings could be from when the engine was new. Like I said, until you start having noises or other signs of engine problems just go with it.
2001 Miata LS 5-speed
post Feb 21, 2013 - 10:52 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
like fine pearly glitter or actual shavings and flakes?
post Feb 22, 2013 - 7:22 AM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
I wouldnt worry about a few shavings. like box said, wait till you hear noises or seeing holes in your block.
エキサイティングカーレーシングチーム!
post Feb 22, 2013 - 9:41 AM
ClevelandGaint
Joined Feb 12, '13
From Cleveland
Ok Thanks guys
QUOTE (Tigawoods @ Feb 22, 2013 - 7:22 AM) *
post Feb 22, 2013 - 10:46 AM
Syaoran
Joined Jan 4, '12
From US
Did it look anything like this???
if not, that's normal. make sure you change the oil more frequently, that's a sign of not-so-good lubrication.
1993 Celica GT Coupe - sold
1994 Celica GT Liftback
post Feb 22, 2013 - 12:28 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
^^^ if it looks like that, you have big problems!! if all you saw was sparkles in the oil then its ok. thats normal to see that a little bit.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Feb 24, 2013 - 9:05 PM
xxgetbackupxx
Joined Feb 20, '12
From Florida
I have noticed shavings when I change my oil, have also noticed my used oil is more reddish in color so it looks more brown and it is kinda alittle sluddgy... if that makes sense any ideas? also by 3000 miles I only drained out about 2 quarts d=-( how long do I have?!?
post Feb 25, 2013 - 9:32 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
QUOTE (xxgetbackupxx @ Feb 24, 2013 - 6:05 PM) *
depends, pop the valve cover and look for sludge.
post Feb 25, 2013 - 1:37 PM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
QUOTE (xxgetbackupxx @ Feb 24, 2013 - 9:05 PM) *
2 quarts of reddish, sludgy oil with metal shavings in it? Sounds like chernobyl reactor #4 waiting to happen. Just keep dumping oil in it till it throws a rod then ducttape the hole and keep on going
post Feb 25, 2013 - 4:27 PM
xxgetbackupxx
Joined Feb 20, '12
From Florida
QUOTE (Smaay @ Feb 25, 2013 - 10:32 AM) *
no sludge under the valve cover... I thinking it just may be coolant.
Lo-Fi Version Time is now: May 29th, 2026 - 8:16 PM
